Author Topic: Where can I get just a float pin?  (Read 1147 times)
traveler
« on: June 29, 2010, 04:17:35 AM »
Where can I get just a float pin?  My float is fine, but would like to replace the pin.
Western Hills Honda sells them WITH the float for close to $50.  OUCH!
Thanks,
~Joe
Offline mystic_1
  • 1970 CB750K
Re: Where can I get just a float pin?
« Reply #1 on: June 29, 2010, 04:24:55 AM »
Go to the hardware store and look in the aisle where they keep the sheet metal.  You should find a rack with varying sizes of brass rod. Compare to your old pin to find the right diameter, buy a couple of feet worth, cut to length, have spare stock to last for years.
mystic_1
- John Augustus Shedd
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #2 on: June 29, 2010, 05:10:47 AM »
I have pins if you want one. Why do you want to replace yours? Too tight, loose, correded? These can be corrected.
« Reply #3 on: June 29, 2010, 06:35:54 AM »
if it aint bent, give it a good polish.
Offline worlddrum13
« Reply #4 on: June 29, 2010, 06:42:24 AM »
i ran in to a similar problem when i was rebuilding a spare set of carbs for a 76 750. they were sitting for who knows how long. In one of the carbs the float was seized to the pin and the pin was seized to the carb. NOTHING would budge them free. i endend up cutting the pin off with a hacksaw. i had to then find a new pin and float.
75 750 k6
« Reply #5 on: June 29, 2010, 09:34:54 AM »
If you try to get your own replacement, mic it.
 I cant think of anything wrong with it that cant be fixed up?.. is it marked up?
Offline mycb750k6
  • Rocketman
« Reply #6 on: June 29, 2010, 11:14:16 AM »
Sometimes they can get really chewed up by a pair of pliars  ;D
traveler
« Reply #7 on: June 29, 2010, 04:42:13 PM »
Screwed up by a pair or pliers...was bent a bit, but I straightened it...re-installed and float moved freely.
~Joe
« Last Edit: June 30, 2010, 04:27:23 AM by traveler »
Offline mycb750k6
  • Rocketman
« Reply #8 on: June 29, 2010, 04:59:47 PM »
Thought so. Been there. Anyway if you need another let me know.
Offline Owned
    • Finished Product
« Reply #9 on: June 29, 2010, 07:25:54 PM »
Just made my own set for a 400F last week.  I found that the local hobby shop had various diameter brass rod in stock.  The job was extremely easy to do.
'01 Ducati 900ssie
'74 Honda CB350F
http://www.flickr.com/photos/indyrider/sets/72157619944545142/show/
'73 Honda CB350/400F Hybrid
http://s1231.photobucket.com/albums/ee520/indyrider2/?albumview=slideshow
'64 Honda CB160 Soon to be unveiled!
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #10 on: June 29, 2010, 07:36:25 PM »
McMaster Carr. I order their high speed drill blanks for everything. You can either buy a pin or rod size. (pin is hardened tool steel) Either way less than $10.
