Author Topic: SOLVED: Front Wheel Dragging? - with video  (Read 2101 times)
Offline grandelatte
  • CB750K1-ish Frankenstein
    • Life is Xampericious!
« on: July 10, 2010, 01:51:26 PM »
Just curious... Does your CB750K front wheel drag as much as mine does?  First I thought the brake was dragging, but then when I removed the caliper & speed sensor, it dragged as much.  FYI, the front wheel has new wheel bearings.
[youtube=425,350]http://www.youtube.com/watch?v=eQ-_p47TquM[/youtube]
« Last Edit: July 11, 2010, 11:50:52 AM by grandelatte »
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
Re: Front Wheel Dragging? - with video
« Reply #1 on: July 10, 2010, 02:23:26 PM »
No, that's definitely not right. Bout all I can offer though.
Offline grandelatte
« Reply #2 on: July 10, 2010, 02:32:56 PM »
thanks - i am tinkering around with it right now.
Offline Johnie
« Reply #3 on: July 10, 2010, 02:35:02 PM »
Did you get the axle spacer in place?
« Last Edit: July 10, 2010, 02:37:06 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline grandelatte
« Reply #4 on: July 10, 2010, 02:37:09 PM »
yeah, it's in there...  i am trying to see if the bearings are in there crooked...
Offline Queeg
  • insane fuel junkie
  • OY! with the poodles allready!
    • Queegs Problems
« Reply #5 on: July 10, 2010, 02:43:44 PM »
front bearing  either worn or the Axel was/is too tight!
 just an idea
guess who?
Offline camelman
  • Man... Myth... Legend
« Reply #6 on: July 10, 2010, 09:37:04 PM »
How did you tighten down the axle bearings?
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline crazypj
  • I'm brill, me
« Reply #7 on: July 10, 2010, 09:50:01 PM »
You did put the bearing spacer back in middle of hub?
PJ
Offline grandelatte
« Reply #8 on: July 11, 2010, 05:17:00 AM »
 just an idea
the bearings are new.  i span the wheel by holding the axle in my hands and it would spin FREELY - over and over for many rotations.
so now the question is...  how can the axle be too tight?  don't you all tighten the axle all the way?  no?
Offline Johnie
« Reply #9 on: July 11, 2010, 06:45:01 AM »
 just an idea
Yes, but like mentioned above if the axle spacer between the bearings in missing it will tighten to much. The spacer looks like the one pictured.
Oshkosh, WI  USA
Offline KB02
« Reply #10 on: July 11, 2010, 07:06:38 AM »
Without the spacer, the bearings end up looking like this:
I would agree that things just look a little too tight. What torque did you tighten them to?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline grandelatte
« Reply #11 on: July 11, 2010, 11:05:59 AM »
 just an idea
the spacer is there.
*You don't see the spacer in there on this picture, since I put the spacer from the retainer side later.
Offline Johnie
« Reply #12 on: July 11, 2010, 11:27:39 AM »
OK, so we know the spacer is in place and can eliminate that idea. Any chance the speedo gear was not in the grooves on the hub?
Oshkosh, WI  USA
Offline grandelatte
« Reply #13 on: July 11, 2010, 11:50:29 AM »
thank you for your continuing support.
i have no idea, but it appears that the forks were pulled too close to the wheel.  i have them corrected and now the wheel turns free!!!!
THANK YOU ALL for your help!
Offline fastbroshi
  • Puppet
Re: SOLVED: Front Wheel Dragging? - with video
« Reply #14 on: July 11, 2010, 12:01:36 PM »
Can you elaborate?
Just call me Timmaaaaay!!!
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #15 on: July 12, 2010, 09:22:46 PM »
Can you elaborate?
+1  Have similar (although not as extreme) problems
