Author Topic: Tips before closing the engine back up.  (Read 631 times)
Offline The_Crippler
  • Work in progress.
« on: July 13, 2010, 08:10:21 PM »
Hey, there - I have an '80 CB650C.  I dropped the case covers off to get coated and will be getting them back this weekend.  Before I close it all back up (generator, clutch, sprocket cover, etc) is there anything that I should check out?  The engine is pretty pristine with only 7K miles, but I wanted to make sure there isn't anything I should look into while it is open.
Also, when I replace the two cover gaskets, do I just put them in place dry, or should they be lubed up with anything?
Thanks in advance!
Offline vern401
Re: Tips before closing the engine back up.
« Reply #1 on: July 14, 2010, 02:03:45 AM »
Just make sure it is all in there right. everything is set to tolerance and properly torqued.
Valve cover gaskets? Put in dry.
Seals and "O" rings I'd lube with a touch of oil first.
LOL dont do like a buddy of mine and forget to set the valves LOL ... He did this on his quad and had a heck of a time getting it to run.... I dont know why HEHEHEHEHEHE. I know it was not funny to him but I got him going.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
  • Work in progress.
« Reply #2 on: July 14, 2010, 05:19:01 AM »
Thanks for the feedback.  Won't have any trouble with the valves, as I'm only doing stuff on the bottom end.
