Author Topic: question....  (Read 970 times)
Offline beks82
question....
« on: July 16, 2010, 11:04:30 PM »
i removed my front wheel and I'm trying to get my speedo off.  Should it come straight out or do I have unscrew a phillips head?  Just curious coz the PO had stripped that screw.....
Offline crousos
Re: question....
« Reply #1 on: July 16, 2010, 11:34:05 PM »
Yes you need to loosen the screw for the cable to come off.
Re: question....
« Reply #2 on: July 16, 2010, 11:53:22 PM »
You have to REMOVE the screw to get the cable out.
Offline cookindaddy
  • I sure love this bike!
Re: question....
« Reply #3 on: July 17, 2010, 03:14:22 AM »
Are you trying to get the speedo cable out or the speedo gear drive out of the hub?
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline beks82
Re: question....
« Reply #4 on: July 17, 2010, 09:52:16 AM »
speedo gear drive....which is why I'm curious you would have to remove the screw for....
Offline cookindaddy
Re: question....
« Reply #5 on: July 17, 2010, 02:01:02 PM »
I haven't taken the speedo gear drive out of my hub yet, but it looks from the service manual (page 12-10) for the 750K8 (what I have) that you need to loosen the front axle nut (on the brake disk side) and remove the axle. That's what holds the speedo gear assembly in place.
Offline vern401
Re: question....
« Reply #6 on: July 18, 2010, 01:34:00 AM »
Yup for the gear you need to remove the axel. for just the cable you need to remove the screw.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
Offline beks82
Re: question....
« Reply #7 on: July 18, 2010, 01:49:11 AM »
roger that's what I was thinking...sorry for not clarifying from the get go
Re: question....
« Reply #8 on: July 18, 2010, 07:46:21 AM »
For some reason those little screws that hold the cable in can be a real you know what to get out if they have been in there a long time. Make sure you have an impact or philips screw driver that fits perfectly as the head strips very easily.Have had to remove two with the little chisel-punch method  :'(  :'(
