My bike rattles, a lot. I went to adjust the cam chain and discovered that the previous owner sheered the bolt head clean off. When you look at it, the bolt is flush with the engine case (possible slightly recessed). There is no way to grab the bolt, I tried an extractor, but that resulted in a piece of extractor bit stuck in the hole I drilled in the 6mm bolt. I was thinking of just drilling the hole larger and tapping it to a bigger thread. My question is where are all of the metal flakes going to end up? If they fall in there, will they pass through the filter and not be an issue or will they get me into trouble? Anyone have any good ideas? I really don't want to take the engine off and tear it apart.
