Author Topic: Can you get replacement key? No Keys!  (Read 1956 times)
Offline Flying J
« on: July 31, 2010, 07:21:37 PM »
I just bought a bike and it has no keys to go with it. Is it possible to get a key cut just from the code on the ignition?
Offline Bob Wessner
  • "Carbs Suck!"
Re: Can you get replacement key? No Keys!
« Reply #1 on: July 31, 2010, 07:28:30 PM »
Try www.Hondakeys.com. All you should need is the number from the lock.
Offline ludo410
« Reply #2 on: August 01, 2010, 01:54:11 AM »
hey ff just take the ignition over to Peat over at APF he will cut one for you on the spot i think it's 9 or 10 bucks just hope all of them are keyed the same...
Offline rockvegas400
« Reply #3 on: August 01, 2010, 03:39:54 AM »
Just got some genuine keys plus a blank from Hondakeys - prompt and good value.
Justin
1975 CB400F
1988 VFR750F-J
Offline Alan F.
« Reply #4 on: August 01, 2010, 05:48:08 AM »
Yup, any locksmith worth his salt will be able to cut a key from the code...or at least make one to fit the ignition switch if you bring it in.
I'm bringing my CM400's switch in tomorrow since they didn't find my code...
Offline Flying J
« Reply #5 on: August 01, 2010, 06:38:03 AM »
Good to know. I was going to go out there to look for a few bits and pieces for this bike.
Thanks
Offline Stogie1020
« Reply #6 on: August 01, 2010, 09:17:18 AM »
Does the same hold true for the seat lock?
PO had uninstalled the seat lock and didn't have the key, but I would like to put it back on...
1978 CB750K
« Reply #7 on: August 01, 2010, 04:31:37 PM »
Yep, seat lock has the code on it also.
1975 CB400F
1988 VFR750F-J
« Reply #8 on: August 01, 2010, 04:37:53 PM »
I've also taken a bike to the locksmith, who made a seat key on the spot!  :)
Offline Stogie1020
« Reply #9 on: August 01, 2010, 05:36:17 PM »
Awesome.  I gotta find a good locksmith then...
This place is great.  Really great.
I am new to riding and to 'fixing' and maintaining things in general, and you guys have all been terrific.  Thanks!
1978 CB750K
Offline Flying J
« Reply #10 on: August 01, 2010, 10:22:53 PM »
Hey bob can you put this in the FAQ somewhere. If its not there already. I did look before posting and could not find it.
Offline Flying J
« Reply #11 on: August 02, 2010, 10:50:13 AM »
Went to local key guy and he made one up off the numbers and it worked. He said that the ones from the internet companies dont always work and he ends up fixing them. Of course he would say that.
