Does someone know is the chrome dish you mount speedo/tacho same in CB550K3 or 750F1/F2 than in CB750K4. It seems that for those part is awaiable from for ex.DSS
but not for K4. If difference is only tripknob its easy make hole with dremel, hole has a grommet so cut wont show. Also will float needles from K7, with its seems Viton points, fit K4 carbs for more consistent fuel level also less leak prone. My Freedom Green K4 is manufactured 7/73 has classic registration here in Finland. Orginally made for US market.
Thanks. Juhani
