Author Topic: How do I rubber mount an engine?  (Read 1361 times)
elcid
« on: February 22, 2006, 01:38:50 PM »
I need to drop an engine (can't say the brand for fear of being called a traitor - let's just say this one is know to vibrate A LOT)  into a softail frame and I want to use rubber motor mounts becaus of the intense vibrations. Any websites that sell them?
I posted this on other forums but all I got is "why" or "deal with the vibration", etc...
This forums tends to be a bit more helpful/ freindly... I hope!  ;D
Are these any good:
http://www.legendmcs.com/Engine/engine-motor-mount2.html
What do I choose from here: http://www.vibrationmounts.com/Products.htm
Do I need the engine stabilizers too? How are these mounted? Any photos of examples?
We are going to fab the tabs but I need to get an idea of what kind of rubber mounts to use & if we even need stabilizers & how to install them.
Thanx!
« Last Edit: February 22, 2006, 01:44:06 PM by elcid »
Offline Jay B
Re: How do I rubber mount an engine?
« Reply #1 on: February 22, 2006, 03:56:17 PM »
A rubber mounted HD frame is a whole different animal than a solid mount. The whole drivetrain, engine, tranny, and swingarm/rear wheel assembly is a solid unit. That powertrain unit is then mounted to the frame at 3 points, a big rubber doughnut in front, and rubber mounts at each side of the swingarm pivot. The stabilizing links are to limit motion to a vertical plane, i.e. front to back and up and down. Without them there would'nt be anything to keep the rear wheel aligned. The reason they did this is because if you just rubber mounted the motor alone, there would still be tons of vibes transmited to the chassis through the drive chain or belt. So they just let the whole works shake on its own. When the Twin Cam softtails were developed, HD found it easier/better for that particular frame to develop a new, counterbalanced motor for it, the TC88B (for balanced) which IMO they should have done 25 years ago anyway. So to give you my take on it, it would be really tough to come up with your own rubber mounting system and have it be very effective. HTH
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
supersport_CB400F
« Reply #2 on: February 22, 2006, 04:00:42 PM »
Buy a rubber pump up set of pants it's less expensive ;D
elcid
« Reply #3 on: February 22, 2006, 04:01:28 PM »
Ahh that makes sense. So just getting some rubber "mounts" & installing them at all engine mount points wiil do nothing really... hmmmm
Offline KB02
« Reply #4 on: February 23, 2006, 05:55:25 AM »
besides, the guys who say "Deal with it" probably only ride a couple of hundred miles a year... if that. They don't know what real riding is, thus don't understand why you would want the vibration to go away.  ;D
Take em out to the middle of a dessert, where no one will be able to see or here them, and let them ride a gold wing for a couple of miles.  :D :D ;D ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline dusterdude
« Reply #5 on: February 23, 2006, 06:00:59 AM »
jay is 100% correct.the fxrt front mount looks something like this.i hope i cut and paste correctly.http://www.vibrationmounts.com/RFQ/VM02014.htm
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
