Author Topic: $#@%ing p.o. - sprocket help?  (Read 1229 times)
Offline domer
« on: August 10, 2010, 01:19:01 PM »
72 CB500, had a bad oil leak so i tore into her, no biggie. in the process i noticed that the chain was rubbing the case. woo-hoo, p.o. used an o-ring chain, lucky for me i caught it before it got bad. no leaks and only about 1/32" deep. so I'm looking for a new chain, and i was asked what size sprockets i have. good question. so i run home to check, to my suprise its running a 18t front and 37t rear. now I'm not a math whiz, nor do i know #$%* about gearing. i am obviously going to have to change this, but why would someone use a gear ratio like this?
on another note, Ive read that an 18t will not fit on the front. Ive put about 1200 miles on that chain sprocket set up and shy of a little wear on the case from the chain, i cannot find any spot where it has touched? i don't have a license (lazy) so i don't take it on the freeway often at all, but i did notice it kind of whines out at 65... but what do i know! thoughts?
Offline scunny
  • don't call me expert
Re: $#@%ing p.o. - sprocket help?
« Reply #1 on: August 10, 2010, 01:27:58 PM »
sorry, can't remember the stock ratio for the 500 but heres a ratio chart to help your maths
http://www.jtsprockets.com/fileadmin/files/jtgearratio.pdf
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Online dave500
« Reply #2 on: August 10, 2010, 02:06:22 PM »
17x34 is the stock 500,the 550 had 17x37 i think,i tried a 37 on my 500 and its way low for me on the road,the 550 had a different primary reduction i think.
Offline eideteker
« Reply #3 on: August 10, 2010, 03:22:12 PM »
http://www.gearingcommander.com/
According to that site, there isn't a big difference between 17/34 and 18/37 - only 3MPH on the top end and little difference elsewhere.  Maybe the PO got a really good deal on that sprocket combo or couldn't find stock size replacements?  If you're going to do a lot of freeway riding at any point, you should go back to stock sprockets or even a couple teeth smaller than stock on the rear to bring the revs down at cruising speed.  Check out Sprocket Specialists - got mine from them.
« Last Edit: August 10, 2010, 03:25:34 PM by eideteker »
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
