Author Topic: oil tank vent leaking  (Read 579 times)
Offline jbrick28
  • ell yeah
« on: August 21, 2010, 11:13:02 AM »
just got my 750 running after it sat in a guys garage for 2 years, i then noticed oil on the ground beneath it. i found what seems to be a vent tube that i traced to the top of the oil tank. what can be the problem?
just cause i talk slow dont mean im stupid
Offline Johnie
Re: oil tank vent leaking
« Reply #1 on: August 21, 2010, 11:31:53 AM »
Any chance the oil is overfull? Keep in mind these bikes that sit a while will allow oil to drain from the oil tank into the crankcase. The people then check the oil level on a cold motor and then add oil which overfills it. Then it comes out the vent tube. Best to check the oil after the motor is warm.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
