Author Topic: Front Brake upgrade  (Read 1308 times)
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
Front Brake upgrade
« on: September 08, 2010, 06:59:29 PM »
I'm currently rebuilding my front brake system and need an a second opinion. My piston in the calipur is useable however Carpy sells a stainless steel piston for $99.99. This would be an inprovement for any future times I have to get into the brakes. I'm also considering one of his drilled rotors even though I have several here that will work fine. I'm doing away with the 2 brake lines and going with one line from the MC to calipur. TAS motorsports is hooking me up there. My question is would the new piston and rotor make a huge difference in my brake system.
People with closed minds cannot learn new things.
Offline vanillagorilla
  • When did I become a
    • The ole Facebook Profile...
Re: Front Brake upgrade
« Reply #1 on: September 08, 2010, 07:05:35 PM »
From what I have read here... It will help a little. I assume you are getting a steel braided brake line? That will help. There is a forum member who makes phenolic brake pistons... Supposed to be much lighter than the metal ones, which reduces unsprung weight(a little), and I think itd be cheaper than Carpys's... I used a master cylinder off a modern CBR1000RR with a SS line, and that made a big difference! I thought it was too stiff at first, but either it got softer, or I got used to it, cause I dig it now! That is all I got on the subject.
Offline cobra2411
« Reply #2 on: September 08, 2010, 07:21:09 PM »
Are you using that master with a single or dual disk setup?
« Reply #3 on: September 08, 2010, 09:14:28 PM »
Single.
Offline HawaiiMike
    • Hawaii realtor
« Reply #4 on: September 11, 2010, 10:52:50 AM »
Try the piston Kevin400F sells.  I think it costs about $35 and it works great.  I have one in my CB550F.
Contact him through this forum or e-mail: kthunter01@sbcglobal.net
