You will need a gear lever with all the linkage, rear brake lever and the 2 front footrest holders. The fiche also shows that the rear brake pivot and brake rod is different. I think you don't have to change it, it's just a revision. I think the height is the same, just futher back about 50mm. it's a quick job to change. there are a few more little things that differ from the early models longer head studs, tank, fuel tap. front fender, exhaust manifold and speedo.
Paul
