Author Topic: CB550 MC piston bore size?  (Read 2708 times)
Offline n9viw
  • Floyd, '76 CB550k
« on: March 01, 2006, 02:12:07 PM »
Hey all,
   I'm considering some brake work, but I need to know what the original bore size of the 550 is to know if my new master cylinder is a sufficient bore size. The one I'm looking at is 5/8" (15.875mm), but I can also get one in 3/4" (19.05mm). Will the smaller one provide sufficient brake pressure?
Thanks,
Nick
Nick
'76 Honda CB550k
'73 Honda CB750k
Re: CB550 MC piston bore size?
« Reply #1 on: March 01, 2006, 02:23:42 PM »
I thought most modern masters were 5/8 which is larger than the 550 original. What does the 3/4 belong to?
Offline volz1fsu
« Reply #2 on: March 01, 2006, 07:14:56 PM »
The 5/8" will give more pressure and less volume of fluid than the 3/4".  If you use the 3/4" the lever will move less and it will be harder to pull.  You should go with the 5/8" if you have the stock front caliper.
Offline dusterdude
« Reply #3 on: March 02, 2006, 06:14:38 AM »
3/4 is for dual discs
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #4 on: March 02, 2006, 09:56:46 AM »
I'm curious to know what bike uses a 3/4" cylinder, anybody know? Maybe a big ole cruiser. I have seen a 17mm model but alot of sport bikes use 5/8 and they all run dual discs.
Offline dusterdude
« Reply #5 on: March 02, 2006, 10:23:12 AM »
i know harley uses 5/8 on single discs and 3/4 thereabout for dual discs.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
