Author Topic: clutch adjustment  (Read 1187 times)
Offline wardenerd
  • '77 550F '81 650C
clutch adjustment
« on: September 12, 2010, 11:32:24 AM »
Just changed the oil and ordered a new chain and sprockets at 35000 miles.  Need help to adjust clutch.  The clutch disengages with very little travel of the clutch lever and while its not slipping I would like to adjust it.  currently the cable at the lever end has about 3/4 of an inch of threads showing and the end by the trnny has the threads all abovethe two nuts at  the bracket that holds the cable .  what di I do to adjust it?
Offline mystic_1
  • 1970 CB750K
Re: clutch adjustment
« Reply #1 on: September 12, 2010, 02:03:08 PM »
Got a manual for your bike?  The clutch adjustment procedure is in it.  If you don't have a manual, go to the FAQ section and download one.
mystic_1
- John Augustus Shedd
Offline 033A2
« Reply #2 on: September 12, 2010, 03:06:42 PM »
I had the same problem until recently I was determined to get the adjustment correct.  Got myself a manual and after two attempts got it so it's releasing about mid-pull. Much better.  Get youself a manual...
K.
Offline wardenerd
  • '77 550F '81 650C
« Reply #3 on: September 12, 2010, 05:35:29 PM »
i have a clymer's and I thought you guy might hsve some inside tips.  thanx anyway
Offline NickC
« Reply #4 on: September 12, 2010, 05:58:30 PM »
Clymer =/= manual  :D
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: September 12, 2010, 06:03:20 PM »
Tip:  adjusting the cable adjusters is the LAST step in adjusting the clutch.
mystic_1
dRoc
« Reply #6 on: September 12, 2010, 08:08:31 PM »
Definitely download the Honda manual. I have both for my 550, and the Clymer often lacks some of the detail provided in the Honda manual. That said, the Clymer sometimes provides more info than the Honda manual in some areas, so I usually cross-reference both, as well as the general Honda repair manual, which can be found here:
http://sohc4.net/index.php?q=content/honda-service-manauls
Print off both the Honda manuals and get them bound at Kinko's for a few bucks. Best investment you'll make :)
Cheers.
