Author Topic: heavy duty studs for the 550  (Read 1686 times)
Offline fastbroshi
  • Puppet
« on: September 13, 2010, 05:47:57 PM »
  I've got some.  So should I apply threadlocker before installing in the block?  I don't see any mention of it in the instructions.
Just call me Timmaaaaay!!!
Offline mick7504
Re: heavy duty studs for the 550
« Reply #1 on: September 13, 2010, 06:00:15 PM »
See reply #1437 http://forums.sohc4.net/index.php?topic=36459.1425
This is Rons (MCRiders) 750 build.
If I was you
I'd be worried about me.
« Reply #2 on: September 13, 2010, 07:37:09 PM »
This is from Precision Machining Inc.
Clean the threaded case holes with solvent and blow clear, dip the stud threads in oil, bottom the studs in the case then torque to 8 ft/lbs max.
Offline fastbroshi
  • Puppet
« Reply #3 on: September 13, 2010, 07:46:47 PM »
Thanks Brent, those are the exact instructions I have too.  Mick thanks, I guess I missed that part of the Phaedrus build.
