I was having problems with my choke not fully closing, in fact only about 25%. Needless to say it was a little hard starting. I had a broken cable plus the previous owner did not have the end of the cable attached on the carb end, so I could not get the butterflies to close. That is figured out and it starts like a charm, but I made some adjustments in the screw I have pictured here. Now, of course, I am not sure how it was set, and being I don't know what it is for, I could use some advice. It sits just behind the 2nd and 3rd carbs where the choke lever connects to the butterfly arm.
Can anyone tell me what this screw adjusts? Obviously is has a significant purpose, and being I have some idle speed and throttle control issues, I have a feeling the two are related. I know where to adjust the idle, but what does this control. Thanks for your advice on my earlier adventure, and hope someone has the answer to this poser!
