Author Topic: cb400f - electrochemically removing chrome  (Read 2344 times)
lohebohi
« on: March 05, 2006, 07:17:57 PM »
Does anyone know of any shops that electrochemically remove the old chrome before starting the chrome process from the beginning on bare metal?
Everyone place I have found just grinds off the chrome.
My reasoning is two-fold.  I want to remove the chrome from the fenders and repaint.  I also want to remove have the 4-1 header rechromed and I feel the only proper way to remove the chrome is the reverse of the application.   I am not interested in any way in abbrasion or blasting as a removal process.
I seen a lot of people say 'a good chrome shop should be able to electrochemically remove the chrome' but every one I have called says they grind it off.  I am in MD and realize I will probably not find a shop in my state.  I could easily drive to Delaware.  My guess is that they are more lax on the use of chemicals in that state.
Thanks
Offline mcpuffett
Re: cb400f - electrochemically removing chrome
« Reply #1 on: March 06, 2006, 03:04:52 AM »
same here in the uk most places just grind off the old stuff  ???  mick.
Offline maksuttt
« Reply #2 on: March 06, 2006, 03:56:17 AM »
You can remove crome with hydrochloric acid or with sulphuric acid.
Check this http://www.caswellplating.com/kits/access.htm#crystals  - chrome stripper
CB-750F 1975
My gallery is here
My blog is here
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: March 06, 2006, 04:09:44 AM »
One thing to consider is that most chrome shops won't even touch the headers unless the insides are as spotless as the outside.
Offline dusterdude
« Reply #4 on: March 06, 2006, 05:25:53 AM »
you could call browns plating,i think they are in tennessee.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Chris Liston
    • http://christopherliston.com
« Reply #5 on: March 06, 2006, 09:14:16 AM »
I'd check with local chrome platers.  Not every piece that is chromed comes out perfectly and they have to re-do the process which involves acid bath to remove the chrome.
I'm in the same boat.  I have fenders and some sidecovers that I want the chrome removed.  I'll be calling around to platers in NJ to see if I can bring my parts in.  I've been media blasting the chrome and on some parts it comes right off, others its a feable attemp.
2008 Triumph Speed Triple Black and NASTY
1976 CB550F Cafe in progress
http://gallery.sohc4.net/main.php?g2_itemId=2402
Offline Bryan Boyle
  • SOHC4 #47 ...one of the Old Pharts
    • The Other Hobby: Restoring Lotuses
« Reply #6 on: March 06, 2006, 09:28:58 AM »
who have you found in NJ that does a decent job...with all the epa and state regs, the number of shops that do chroming
is a lot fewer than in my callow youth when I was busy rebuilding various english attempts at automotive sculpture and needed
parts redone...
Inquiring minds would like to know.  I have a pile in the storage locker than need work...:)
Bryan
SOHC4 #47
Proud member since 1994, active on and off
Commercial Pilot/Flight Instructor-Instrument/A&P
Morrisville PA
'63 CA95, '64 CA77, '73 CB350F, '73 CB350F, 2 Lotus Europas and Lots of Parts All Over The Place
Offline Kevin
« Reply #7 on: March 06, 2006, 03:17:12 PM »
I did have a used set dipped to strip and rechrome, the acid ate right through the pipes. I ended up buying a complete new set, and then having them rechromed with real american chrome (triple chrome plated), as you can see it came out looking awesome.
Good luck!!
Kevin
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #8 on: March 06, 2006, 03:45:39 PM »
So most places won't even look at your stuff unless it's operating room-clean?
Hmmm...Makes me rethink having my exhaust replated.  I mean, I would love to, but if they won't touch it....
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: March 06, 2006, 03:57:25 PM »
Maybe you could plug up the ends so the carbon build-up doesn't contaminate the chrome bath.  Just a thought...
lohebohi
« Reply #10 on: March 06, 2006, 05:08:54 PM »
Kevin, how bad was the rust on the set that you took in?  That is also a secondary fear of mine.  I am worried that the base metal is pretty thin to begin with.  How about the fenders and chain guard?  I would hate to pull the piece out of the acid bath and see that the piece no longer exists.  Maybe since the original chrome was so thin, the piece should be pulled out of the bath much sooner than normal.
Is there an alternative to blasting, sanding, or acid dipping?
Offline maksuttt
« Reply #11 on: March 07, 2006, 04:00:03 AM »
Yes.
Alkiline process. Some kind of galvanizing.
Plating shops can do it.
Check it here http://www.nmfrc.org/crarchive/jan02a.cfm
CB-750F 1975
My gallery is here
My blog is here
Offline petescb
« Reply #12 on: March 07, 2006, 03:51:05 PM »
I wouldn't happen to know about any environmental regs regarding chroming in the UK, but in the States most shops would first "pickle" the part in an acid to remove the chrome, then polish the metal to remove as many pits as possible, then chrome it in three steps (nickel, copper, chrome).  It's standard and straightforward.
« Reply #13 on: April 25, 2006, 11:16:33 PM »
The reference to Brown's is close but not TN. It's 1010 Krebs Station Rd ; Paducah, KY 42003 270-554-1146. Excellent work if they will do this for you. I had my valve cover chromed there approx 1977 and it still looks great. They once again do retail. Hopefully the phone number is still the same. Was 502- which has changed to 270- and the zip was 42001 but has changed. This phone number is from Custom Bike 12-1982 but I know the area code has changed. Once a Paducahan, always a Paducahan.
Offline dusterdude
« Reply #14 on: April 26, 2006, 09:02:27 AM »
hell,i was close. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #15 on: April 26, 2006, 05:41:35 PM »
Hell, KY - TN , we all sound alike.
Offline kaceyf2
« Reply #16 on: May 02, 2006, 06:34:22 PM »
chrome can be removed by the obvious way.....reversing the anode in solution....chroming exhaust headers in Uk is no problem..see "blue" paper that comes with "tansha" (VJMC magazine) approx thirty pounds per header!  With thin parts,one can build up the copper over none leaded "soldered in" build up, use like filler, and make even thicker if required by copper-forming principle....polish, then nickel ,polish then chrome. again refer to caswell plating.com..........made simple.
In my own experience...
It wasn't a Previous Owner who didnt know what he was doing that messed up your bike, it was The Previous owners mate who THOUGHT that HE did.
