Author Topic: You know your in Texas, or Arizona when . . .  (Read 1635 times)
fuzzy2bucks
« on: October 22, 2010, 11:43:12 AM »
 You know your in TEXAS or Southern Arizona when. .
- The  birds have to use potholders to pull worms out of the ground.
- The best parking place is determined by shade instead of distance.
- Hot water now comes out of both taps.
- You can make sun tea instantly.
- You learn that a seat belt buckle makes a pretty good branding iron.
- The temperature drops below 95 and you feel a little chilly.
- You discover that in July it only takes 2 fingers to steer your motorcycle.
- You discover that you can get sunburned through your car window.
- You actually burn your hand opening the gas cap on your motorcycle.
- You break into a sweat the instant you step outside at 7:30 a.m.
- Your biggest motorcycle wreck fear is, "What if I get knocked out and end up lying on the pavement and cook to death?"
- You realize that asphalt has a liquid state.
- The potatoes cook underground, so all you have to do is pull one out and add butter, salt and pepper.
- Farmers are feeding their chickens crushed ice to keep them from laying boiled eggs.
- The cows are giving evaporated milk.
Offline MoMo
  • Ride like you're invisible
Re: You know your in Texas, or Arizona when . . .
« Reply #1 on: October 22, 2010, 12:10:37 PM »
Was stationed in San Antonio in the 60's-you're right on with your descriptions!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: October 22, 2010, 12:16:16 PM »
Had occasion to make business trips to both Phoenix and Houston. Swore I would never go back voluntarily. I hate heat, I hate humid heat even more. Seems pretty accurate to me also.  ;)
Offline kirkn
« Reply #3 on: October 22, 2010, 01:08:19 PM »
Sounds just like Central Florida, too!  HUMID heat.  Ugh.
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #4 on: December 13, 2010, 09:06:22 PM »
just came across this. These are all true...
music
« Reply #5 on: December 14, 2010, 06:08:06 AM »
None of it is true! At least not today, as it will be "only" 70 degrees today in Central TX.
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #6 on: December 14, 2010, 06:20:39 AM »
Yeah,but its the middle of December. At this rate summer highs will be in the 130s.
music
