Author Topic: Advance retard unit removal  (Read 1188 times)
seabird
« on: March 11, 2006, 10:09:53 AM »
I'm in the throes of replacing my clapped-out Pirhana/Newtronics Electronic Ignition system with a Boyer-Bransden Microignition system.
I've sorted out the wiring, and am attempting to remove the advance/retard unit with bob-weights etc., as the new system doesn't use tem.
I'm at the stage of attempting to slacken the small 10mm bolt (and after, the larger nut) on the end of the crankshaft, but try as I might I can't undo the small bolt as the crank keeps turning.  I put the bike ('75 CB400F) in 1st gear and wedged the rear wheel, but the damn crank continues to turn.
Any handy tips on removal of the offending bolt/nut?
Thanks in advance,
Seabird
Online Tim2005
Re: Advance retard unit removal
« Reply #1 on: March 11, 2006, 10:25:07 AM »
Er, have you tried putting a ring spanner on the bigger nut behind it & holding it still with that?
supersport_CB400F
« Reply #2 on: March 11, 2006, 01:05:01 PM »
Get your missus to sit on the bike with it in gear and  get her to hit the rear brake, if you don’t have a ring spanner.  ;D
