Author Topic: Sidecover restoration . . . the "anti-bondo"  (Read 1978 times)
Offline Red750K1
« on: June 01, 2008, 10:43:30 AM »
Hey all, I've picked up a few extra sets of '71 to '76 sidecovers to repaint and flip for some extra summer project cash. A few of them have had the 750 four badge area smoothed over (with bondo I expect). Any advice on getting these back to stock?  I dont want to just stick the badges over them so thats not an option. Is there any chemical stripper that would get the old crud paint off and maybe remove the body filler as well? or am I stuck sanding? Any tips?
Offline WFO
  • Will work for powerbands
Re: Sidecover restoration . . . the "anti-bondo"
« Reply #1 on: June 01, 2008, 11:31:35 AM »
I bought this stuff called bumper stripper SEM 39913 to get paint/crud off a TY 250 fender and it worked perfect it doesn't damage the plastic what so ever i got it at the local automotive paint supply shop.
« Last Edit: June 01, 2008, 11:44:17 AM by WFO »
82 cb650 sc nighthawk - 78 kz 650 b
Offline kghost
« Reply #2 on: June 01, 2008, 11:41:45 AM »
I just pick it out with an x-acto knife.
Stranger in a strange land
« Reply #3 on: June 01, 2008, 01:39:02 PM »
+ 1. Comes off fairly easy once u get started.
Offline 750K2
  • new rider with an old bike
« Reply #4 on: June 01, 2008, 03:54:30 PM »
no expert here but i'd go along with picking the bondo out with a putty knife. once you get a corner out the rest ought to pop out fine.  for the paint, i'd be leary of using a remover as that plastic is old, brittle and expensive to replace.  i worked with andy on his side covers and we did well with a random orbital sander and A LOT of hand sanding.  then i bought some two part putty filler and did the fill, prime, sand, fill, prime, sand routine.  any way you look at it, it's labor intensive so as a psuedo-businessman, watch your hours.  don't know if this helps but good luck!
frank
Offline fmctm1sw
« Reply #5 on: June 01, 2008, 06:44:01 PM »
I had good luck punching a nail where the original holes were on the back of them...  Popped off a big piece...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Red750K1
« Reply #6 on: June 02, 2008, 08:48:43 AM »
Awsome, thanks guys. I'm going to try and pop the junk out from the back side through the badge mounting holes, I'll let yall know how it works. I'll also try the bumper stripper. I've got a nice nice nice set of K0 sidecovers that someone buggered with crap paint and its too thick to sand (i'd be sanding till the fall) so i'll try the bumper strip on those. Thanks again!
Offline WFO
« Reply #7 on: June 02, 2008, 09:20:14 AM »
Just so ya know that fender i was stripping was a old original i wanted to sell it on ebay and it turned out better than i imagined and best part was i got 80 bucks for it.  ;)
