Author Topic: Newbies...pay attention to the FAQ  (Read 3322 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: December 02, 2010, 03:11:44 PM »
I am definitely a newbie.  Got a bike about 2 months ago now, and have slowly been teaching myself (or being taught by members here) about how to fix my ratty CB550k.
After a ton of help here on the forum, I made my way painfully (probably more so for those who had to redundantly answer my questions) through the tune-up process for the first time.
By the time I hit the timing adjustment, I was feeling fairly good.  I got the 1/4 aligned perfectly.  Nice!  I'm on a roll!  On to the 2/3 alignment, and stopped dead in my tracks.  I ran out of room to move the 2/3 point plate any further counterclockwise.
I found a post in the FAQ about this very issue.  Two-Tired had posted why, what, when, and where this issue occurs.  I read it, got some clarification, and today, finally got around to trying the "shim" fix he details in the FAQ.
Bingo!!!!  For the first time, I have spot on timing.  And I mean spot-the-f%#k-on!!!!
Thanks to all the guys who offered their expertise and patience.  And for those of you who are trying this whole carnival ride for the first time, trust the FAQ.....
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline cookindaddy
  • I sure love this bike!
Re: Newbies...pay attention to the FAQ
« Reply #1 on: December 02, 2010, 03:19:46 PM »
Wow - like in Startrek - "use the FAQ Luke, use the FAQ!"
A nice note.
I too have found much good stuff in the FAQ also as I have progressed in my understanding.
You are perceptive to point this out for newcomers and some not so newcomers.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: December 02, 2010, 03:59:08 PM »
I hope the FAQs aren't copy righted becasue I've been printing them off like crazy. Now I have a notebook folder full of them in my workshop.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #3 on: December 02, 2010, 04:07:15 PM »
I have read posts giving credit where credit is due, and hopefully I have done this as much as I should.
But it's definitely worth noting that at times, the directions listed in some FAQ posts are laid out in terms and understanding that are over my head.  I would assume that others have run into this as well.  The key is really studying it, hopefully while in front of the bike.
I have started to copy/paste my research in the FAQ into a document I can read on my phone while down on the curb (Brooklyn curb workshop).  Incredibly helpful.  And then when I hit snags, I can be confident that I have done everything in my power to "search" and utilize the site before I post.  And I think that's what the more experienced members are hoping for :)
The wealth of knowledge on here is amazing - and the feeling of satisfaction when you nail the fix is intoxicating!!!
~Sophocles
Offline Bluegreen
« Reply #4 on: December 02, 2010, 04:10:20 PM »
A nice note.
Star WARS man  ;)
Offline cookindaddy
« Reply #5 on: December 02, 2010, 04:46:27 PM »
Star WARS! Not Star TREK!
Yes.
Thanks
It is all blending together at my age
« Last Edit: December 02, 2010, 04:48:07 PM by cookindaddy »
Offline MagneticWest
« Reply #6 on: December 02, 2010, 06:05:25 PM »
Totally agree with Nortstudio on the incredible resources available here.  I too used Two Tired's shim fix on the points plate a couple of months ago, and it was sweet indeed to finally get the slop out out of the timing adjustment.  A belated thanks to you TT!
Dave
1975 CB550 K1
« Reply #7 on: December 02, 2010, 07:23:38 PM »
Nort - you've come a long way, brother!
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #8 on: December 02, 2010, 07:27:12 PM »
Trying...oh lord I'm trying :)
~Sophocles
« Reply #9 on: December 02, 2010, 07:31:34 PM »
That's a big part of bike repair. If you tell yourself you can't do it, you won't. If you at least try, you'll get there.
Offline Really?
« Reply #10 on: December 02, 2010, 07:34:58 PM »
Learning the Search Fu can take a bit though.  The biggest help with this is to search while on the Home page.  The next is using the right keywords.  I have been here for a bit and still struggle with the Search Fu a bit.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #11 on: December 02, 2010, 07:37:07 PM »
I'm actually having a great time with all  this.  Frustration, even at it's height, has been fairly low.  I have grown into an attitude with this where I realize that things will get done...eventually.
I think they call that...getting old! :)
Seriously, knowing that this forum exists, and is here for you, allows you to try some things that normally might make you run to a proper mechanic.  So now, I take a deep breath, smoke a cigarette, look up stuff on this site, and then dig back in.
Now when I quit smoking...no way of knowing might happen! :)
~Sophocles
Offline Spanner 1
« Reply #12 on: December 02, 2010, 07:37:41 PM »
Kudos to TT ( x1,000 ! ) for his input here.... if you like , when your timing is set via TT's method, you can pull the shims and 'peen' the 3 points plate holders with a hammer and nail-set punch... carefully to close-up any gap to the plate.... the trick is carefully.... then your timing/gap should always be re-setable down the road  ;)... once you never put a wrench on the points advancer/cam nut to turn-over the crankshaft...( just don't do that !!) your good for 'ever'  :D
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #13 on: December 02, 2010, 07:41:45 PM »
No question the search can be a little frustrating.  I have had trouble with putting things in quotes to get an exact match, come up with nothing - but later find that exact phrase.
A trick I finally figured out was to start at home page - unless you know you want a trick, and then go into that page, and then search.  Narrows it quite a bit.
I have been advancing the points cam with a wrench.  I read a whole thread about it debating back and forth, and eventually decided to just be very careful with it.  Timing is on for now, so I will give myself just tonight to enjoy this glow of satisfaction :)
I've actually had better luck at times searching in google, and scrolling to the link on SOHC.
~Sophocles
Offline Ouch
« Reply #14 on: December 03, 2010, 05:20:30 AM »
To make like simpler i put a computer about 5 feet from where i work or my bike. Got tire of haveing a problem...going to the computer room..than back to the garage....makes life easire!!!  ;D
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #15 on: December 03, 2010, 05:55:35 AM »
4 flights and no wireless makes this tough for me - but I have to admit, this is when the iPhone shines...
Of course with as much looking as I need to do, the battery has certainly shown it's weak side :)
Looks like soon I may have a basement space to at least take parts off and work on them down there (ventilation will be a challenge to overcome - but we will figure something out).  Should be able to get a computer down there.  That will be pretty sweet.  I have to say though, the frustration/satisfaction ebb and flow I had yesterday kept me fairly comfortable while wrenching in 42 degree weather on the street.
It's amazing how much energy and heat being pissed can generate!
~Sophocles
Offline ZoomyZen
  • Nube
  • Yup.
« Reply #16 on: December 03, 2010, 06:01:58 AM »
Hot DAMN!  That's the greatest FAQ I have EVER seen.  And I'm a mod on a fishing/huting forum, I kinda know what I'm looking at.
As far as the structure goes, that is a really great concept...  I'm going to suggest it to my admin!  Thanks!
1975 CB550F non-functioning.
« Reply #17 on: December 03, 2010, 07:20:01 AM »
Spanner, if you don't mind, could you expound on the peening?  What surface are you peening with the nail punch?
I actually left the shim in place - just drilled a hole thru it so that the screw for the points plate goes thru the shim and locks it in place.
I plead guilty on turning the crank over by wrenching the cam nut (that's what the manual describes).  What method do you use?
Thanks!
Dave
1975 CB550 K1
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #18 on: December 03, 2010, 10:56:52 AM »
I'm a little gray on that as well. peening?  I've seen the shim with screw method. My gap was only .008 so I used a gauge and didn't have the heart to leave it in there when I closed it up. Probably should have sacrificed it....
~Sophocles
« Reply #19 on: December 03, 2010, 01:22:07 PM »
Peening, flattens/stretches the metal plate, effectively making the plate larger.
If you had a ball of putty in your hand and flattened it, the outer circumference gets larger in one dimension.
The steel plate is ductile and behaves in a similar fashion if you mash it between something.
You can do this with an anvil and hammer, if you take the plate off the bike.
Or, you can use a pointy center punch and tap a bunch of divots in the plate surface near it's outer edge at the point where it mates with the case guide posts.  This expands the metal some at this point.  I hesitate to recommend doing this on the bike, though.  Because my concept of light hammer hits may be different than what an inexperienced person may assume.  A steel plate is less ductile than the aluminum case of the motor.  Easy to replace the points plate, not so easy to replace the motor case.
« Reply #20 on: December 03, 2010, 01:32:52 PM »
Ahh, I get it now - peen the points plate.  Makes perfect sense.  Thanks Lloyd!
Dave
1975 CB550 K1
Offline mystic_1
  • 1970 CB750K
« Reply #21 on: December 03, 2010, 03:51:51 PM »
It sounded to me like Spanner was suggesting peening the case guide posts.  Peening the points plate does sound better.
mystic_1
- John Augustus Shedd
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #22 on: December 03, 2010, 03:59:32 PM »
I am personally going to stay away from the peening until I feel as "experienced" as TT.  God knows, I would probably smack the plate too hard creating an overhang that then needs to be trimmed....peen and trim....peen and trim.
The damn thing would end up the size of a silver dollar and worth half that! :)
~Sophocles
« Reply #23 on: December 03, 2010, 06:03:19 PM »
mystic_1
If that IS the case, then I would question which part was/is made "out of spec.", the plate or the mount posts.  Certainly both parts are made to a tolerance.  But, if the specimen plate was made too small, and the case mount posts changed to fit it tightly, then the next plate, if made larger (but still within tolerance) during its production, wouldn't fit inside the case posts.
I would rather massage/modify the much cheaper and easier to replace points plate, rather than the case posts, unless I knew the case posts were made poorly and needed "correction".
Offline country joe
« Reply #24 on: December 03, 2010, 10:06:23 PM »
I too have learned much from this forum as well, and always thank any help I get. I'd be doing a lot of head scratching if it weren't for this forum. I come from a Harley, and British bike family so the world of SOHC's was very new to me. Glad I found y'all!
'78 Honda CB550K
'79 Yamaha IT400
'74 H-D Sprint 350 (basket case)
