Author Topic: CB550 vs CB550F  (Read 6048 times)
Offline ZoomyZen
  • Nube
  • Yup.
CB550 vs CB550F
« on: December 03, 2010, 12:26:24 AM »
Hello everyone, I'm very new and preparing to tear down a CB550F.  This is my bike:
I got it just the other day, rather I assumed ownership the other day, I might be able to pick it up Sunday.    ;D ;D
As of now I'm just familiarizing myself with this environment and trying to come up with a game-plan.
*Warning - Nube content to follow*
Would anyone be willing to share just how a 550F differs mechanically from a 550, or perhaps any advice that might pertain to a project like this?  First off I will need to free up the front break, preferably before I try to load it into my pickup.  I guess I'll go with the grease-gun trick.
Thanks!
1975 CB550F non-functioning.
Online dave500
Re: CB550 vs CB550F
« Reply #1 on: December 03, 2010, 01:00:50 AM »
just remove the entire caliper to get it rolling.
Offline ZoomyZen
  • Nube
  • Yup.
Re: CB550 vs CB550F
« Reply #2 on: December 03, 2010, 01:08:42 AM »
Well that's a thought LOL!
Good logic lesson..  Correct isn't always the best method.  Thanks!!
Offline Fritz
Re: CB550 vs CB550F
« Reply #3 on: December 03, 2010, 01:51:38 AM »
Yes, you'll only need to loosen the two caliper bolts with a 14mm socket to free the front brake. You don't even need to remove them.
Regarding the differences between a CB550(K I suppose) and a CB550F:
Exhaust: 4-4 exhaust (K), 4-1 exhaust (F)
Frames differ in some aspects related to the different exhausts - depending on the model year.
Rear brake lever
Kickstarter
Footrests
Carbs: Different jets, different carb type and manifold on the K3 since '77
Air filter element - Important: you'll need part no 17210-390-003 or 17210-390-P00 for the F model. The filter for the K models are similar but won't fit (17210-404-670 or 17210-404-P00)
Side covers
Seat
Rear seat bar
Wire harness
All other parts should be interchangable
1976 CB550F
Offline ZoomyZen
  • Nube
  • Yup.
Re: CB550 vs CB550F
« Reply #4 on: December 03, 2010, 02:00:52 AM »
Wonderful!   Thank you!
Re: CB550 vs CB550F
« Reply #5 on: December 03, 2010, 05:33:11 AM »
Mechanical - same motor and trans, carbs are differant as stated above. Of course, these items are all on stock models, no telling what has been changed over the last 35 years!
Look here for more info-->> http://www.sohc4.net/index.php/cb550/cb550-model-guide
+1 on just loosening caliper, did it last month.
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: CB550 vs CB550F
« Reply #6 on: December 03, 2010, 11:58:19 AM »
Also front forks internals are designed a bit different too. Better damping I assume.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Re: CB550 vs CB550F
« Reply #7 on: December 03, 2010, 06:09:04 PM »
Which one is better? First I heard this.
Offline fmctm1sw
Re: CB550 vs CB550F
« Reply #8 on: December 03, 2010, 07:06:29 PM »
the service manual (available here) has a chapter on the differences between the 500 and 550 in one of the chapters and a 550F supplement at the end.  Maybe some clues there...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Bluegreen
Re: CB550 vs CB550F
« Reply #9 on: December 04, 2010, 11:16:22 AM »
The later model.
