Hi again, thanks, I will check the service bulletin if I can find it.
But I had a second thought after reading Hondamans text over again. What he are telling, is the opposite of what I have read earlier in other posts. As I can understand, he means that the early sandcast hub is narrower and the later is wider. I have checked the Honda 750 parts list and the through-hub bolts for the disc are 106 mm from the beginning to frame-number 1044650, and the bolts are 102 mm after that number. And wouldnt it be more logical to have a narrower hub if you want to add a second disc? To me that points to an wider early hub? Please help me out on this, have I missed something that I dont understand?
/Ken
