Hi Bob,
Its only 19 KB, and isn't Gearcalc (just had a look at that - its a bit more sophisticated than most of us would use I think).
As is said earlier - I'm no programmer, but this will give a quick idea of how speed or rpm will change with different sprockets. And it runs in Micrososft Excel, which most people would have. And of course the calculation was originally posted by Jeff Saunders, so I am not the brains behind it.
Here's a cut and paste version (which looks a bit odd due to the format):
Input your Results calculated
data here here
Current setup front sprocket 17
rear sprocket 47
ratio (rear / front) 2.76
New setup front sprocket 18
rear sprocket 48
ratio (rear / front) 2.67
Speed calc current speed @ XXX RPM 65
new speed @ same RPM 67
RPM calc current RPM @ YYY speed 4500
new RPM @ YYY speed 4340
I can pm you or Steve with the file if you like. If it's not usefull, no probs.
Neil.
