Author Topic: Need help  (Read 1081 times)
Offline 765fitty
Need help
« on: January 01, 2011, 12:23:39 PM »
In determining wire sequence.
1976 Honda CB 550
Thank you.
Save your $. Adopt an old Honda and give it a nice home.
KingCustomCycles.com
Re: Need help
« Reply #1 on: January 01, 2011, 12:26:29 PM »
1-2-3-4 from the left as sitting on the bike? I think I understood the question......
Offline Hush
Re: Need help
« Reply #2 on: January 01, 2011, 12:29:55 PM »
Yep or as per your photo 4,3,2,1 just remember that the coils are another matter entirely when you get to them, one runs 1,4 and the other fires 2,3.
Motor looks pretty good too. :)
Re: Need help
« Reply #3 on: January 01, 2011, 01:39:42 PM »
The firing sequence is 1,2,4,3.
The spark lead connectivity is 1 and 4 for the coil with the Blue wire, and 2,3 for the coil with the yellow wire.
As you sit on the bike, the cylinders are numbered from left to right 1,2,3,4.
Offline 765fitty
Re: Need help
« Reply #4 on: January 01, 2011, 05:07:39 PM »
Hey thanks.  This is before motor restoration.
Thanks man!
I can check later, but do you know off hand which color wire for left and right coils?
Offline cafe550
  • 74 cb550four
Re: Need help
« Reply #5 on: January 01, 2011, 05:11:28 PM »
I HAVE THE SOHC4 SICKNESS!!!
Offline camelman
  • Man... Myth... Legend
Re: Need help
« Reply #6 on: January 01, 2011, 05:24:53 PM »
Your wires should naturally fall into position.  They've hardened so much over the years that they are more like plastic now, so they'll hold their routing form.
By the way, if you are going to rebuild that engine, then I highly recommend doing an ignition wire replacement too.  There is a good "how to" in the FAQ section.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline 765fitty
Re: Need help
« Reply #7 on: January 02, 2011, 08:37:41 AM »
Thanks guys.
Your information has been a big help.
Onward!
