Author Topic: Homemade Tool Question  (Read 1660 times)
Offline nomadwarmachine
  • 1972 CB750K2, 1974 Norton Commando 850 Mk2
    • Nomadwarmachine.com
« on: March 26, 2006, 02:29:29 PM »
Anybody know the size of the socket that I need to notch to create a tool capable of removing the clutch hub nut?  I am swap in a new Barnett 9-plate clutch when I change the oil next time, and want to have my tool ready to go before I crack into it.  Thanks!
Re: Homemade Tool Question
« Reply #1 on: March 26, 2006, 03:52:41 PM »
 Just to let you know...the Honda part is not that expensive.  I could give you a price.
« Reply #2 on: March 26, 2006, 04:06:42 PM »
That would be great -- have you got a part number?
« Reply #3 on: March 26, 2006, 04:17:07 PM »
Oh boy...now I'll have to look.......
Offline Jonesy
  • Shop Rat
« Reply #4 on: March 26, 2006, 05:12:10 PM »
I got mine from Z-1 Enterprises. Was just over $20. I just used it to swap in the late-model anti-rattle clutch assembly.
Offline Clyde
« Reply #5 on: March 26, 2006, 07:33:37 PM »
I also got a clutch tool from Jeff at ZI as below
Clutch Hub Nut Socket
KL35-9459
K&L
Clutch Hub Nut Socket, 24x20mm
$28.96
The 24mm refers to the inside diameter and is the one for the honda clutch. It uses a 1/2 inch drive.
The tool Jeff sells has both 20 and 24. I looked at others but they looked very cheap and nasty.
See his site
www.z1enterprises.com/detail.aspx?ID=2161
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
