egar,
The best way I can explain it is: The steering head ( more often called the triple tree) is the part
that your upper fork tubes, headlight w/brackets(or mounts) and handlebars are attached to. It
may need to be adjusted, the bearings may need to be relubed or replaced. Hope that gets you
started. Later on, Bill
