Author Topic: Spark plug Caps 750K8???  (Read 1371 times)
bollingball
« on: January 25, 2011, 05:53:36 AM »
 Was doing my 2.5K  ;) tune up looking at my caps this is what I got on my Simpson 260 #1=2.8ohms #2=open no reading #3=5.4 ohms #4=3ohms (not K ohms). The bike runs good other than hard to start however I'm getting new caps. I can not find a part # in the manual in the ignition sec. it shows the coils but not the caps.When I go on line three different sites show them as item # 7 & 8 and the have three # 7 & 3 # 8 I don't know what the difference is and the (Boy) at the Honda shop does not either. Can anyone HELP with part # for the 5 K ohm caps two straight two bent looks like 30 to 40 degrees.
           PS Bike runs the same with DR8EA or D8EA  ??? WTH. Also can go with NGK or OEM Thanks for any help
Offline luder
Re: Spark plug Caps 750K8???
« Reply #1 on: January 25, 2011, 07:05:55 AM »
Dont remember the part# but I  ordered mine thru carquest,just tell them what your looking for.....luder
bollingball
« Reply #2 on: January 25, 2011, 07:30:41 AM »
Thanks luder any others Spanner1 TT
Offline Skunk Stripe
« Reply #3 on: January 25, 2011, 07:58:01 AM »
Use the D8EA plugs, your bike will run better.
http://www.z1enterprises.com/catalog.aspx?pid=CB750K-1978-IG0
They have caps here that are ngk which is what the bike came with stock. You need 2 (SD05F)straight and 2 120 degree (VD05F) elbow style caps. Should be the 12mm caps.
http://www.z1enterprises.com/reference/Z1-spark-plug-guide.aspx
« Reply #4 on: January 25, 2011, 08:54:22 AM »
The plugs you can get at AutoZone. The caps you can get from Z1.
bollingball
« Reply #5 on: January 25, 2011, 09:35:08 AM »
Thanks Skunk tha is the # I needed  :)
« Reply #6 on: January 25, 2011, 09:46:13 AM »
I am useful sometimes! :D
