I am combining parts from two sets of carbs to make one nice set of 627B carbs. I am finally done cleaning and sorting and ready to begin reassembly. I have looked at the manual on the home page and this site http://www.motorcycleproject.com/motorcycle/text/specs.html and I get a bit different information. In addition, I have some slight mods to account for. I would appreciate any advice to get me very close to correct first try.
I will be running a Mac 4-1 exhaust and will possibly shorten the baffle a bit.
Factory air box with a foam Uni filter. I am missing the air box cover right now but hope to find one. All other specs as far as timing, valve adjustment, etc. will be set to stock. The only other change I may make once I get it running is Hondaman's ignition mod.
The specs that I have found show 100 mains, 40 slow jets, 22mm float height, 4 on the needle. Does the 4 mean 4th groove from the top?
I have both 100 and 110 mains available. I live at 1300 ft so factory sea level settings generally apply. I know that on most modern bikes I have owned they have generally come lean from the factory for emissions reasons but I'm not sure if that rule applies to a 72 model. Any advice that might save me from dismantling these again would be greatly appreciated.
My best guess would be to install the 110 mains, and cross all fingers and toes. This guess is based solely on the change from the stock exhaust and air filter.
