Author Topic: Comstar Rim Rivets  (Read 3052 times)
Offline 7fiddyfoz
Comstar Rim Rivets
« on: February 07, 2011, 11:31:03 PM »
Hi Guys,I have a couple of rivets that are loose on the rear Comstar of my 1977 CB750 F2 .Is there a way of tightening these up,I was thinking of a hydraulic press. I would appreciate if some of you experts out there can throw some light onto this as I'm sure this has happened to others before.
Thanks in advance,
Steve in AUS
Offline KRONUS0100
  • MAD MATT THE MANIAC
Re: Comstar Rim Rivets
« Reply #1 on: February 08, 2011, 06:03:26 AM »
are the rivet holes elongated?  what caused them to come loose.............pothole?  if holes are elongated I wouldnt use the rim anymore.
MATT
Offline Hush
« Reply #2 on: February 08, 2011, 07:52:39 AM »
A bit dodgey using them again, you could try to press them flat again and see what the result was, if they don't work out get another set.
Offline Halvin
  • Life is 10% what happens to me & 90% how I react.
« Reply #3 on: February 08, 2011, 08:08:36 AM »
Hush,
I too have a poblem with comstarts on a 77 F2.  Is there a supplier where someone can ".....get another set"?  If not is there a replacement alternative?
Halvin
Hal
Offline KRONUS0100
« Reply #4 on: February 08, 2011, 10:44:37 AM »
only alternative I know of right off the bat is a set of wheels off a gs series suzuki....they are almost direct fit.  some finaggling with the front brakes to space em right.  you would have to have the rear caliper and mount for the rear if disc brake rear.  The rear drum brake is direct swap.
MATT
Offline 7fiddyfoz
« Reply #5 on: February 09, 2011, 10:25:34 PM »
Thanks for the replys,
Holes don't appear to be elongated, there appears to be a small amount of movement up and down not sideways.I dont know if the PO had hit a pothole or not. The bike has very low K'S, did read somewhere where early Comstars had this problem. Does anyone have a real good rear Comstar that they may want to sell.Postage to Australia may be a problem but I could check this out
Regards Steve
