Author Topic: 76' 550k timing question ???  (Read 1329 times)
Offline jimkalfakis
« on: February 10, 2011, 06:40:50 PM »
Hey dudes! I finally got this thing running and running real good after a carb rebuild. I'm using a MAC advanced timing light. It's running smooth at 1000 rpm and I got the strobe light right on the timing marks. How do I check the advance? When I rev it the timing mark goes to the left. If I set the advance on the light to 25* advance and rev it, the timing mark still just goes over to left. What am I looking at? What am I looking for. I'm using the manual but still.
*1976 Honda 550 Four
*2003 Kawasaki Vulcan 1600
*2000 Ford SVT-Lightning 426 RWHP 546 RWTQ
Offline MoMo
  • Ride like you're invisible
Re: 76' 550k timing question ???
« Reply #1 on: February 10, 2011, 07:33:16 PM »
At idle the light should fire at the 'F' for the respective set of cylinders and when revved the light should fall between the two advance marks.  To clarify a bit-the light illuminates the F mark at the  notch on the crankcase and when revved the light illuminates the two advance marks at the same notch.  My 30 year old Snap On timing light does not have a setting for advance..Larry
« Last Edit: February 10, 2011, 07:59:15 PM by photolar »
Offline jimkalfakis
« Reply #2 on: February 10, 2011, 07:42:26 PM »
Yes, at idle it's on the F mark. Don't I have to set the advance on the light to approx 26 degrees and rev to 2500 rpms. Shouldn't it still be on the F-mark.
I think I should be a little more specific. I'll check it better tomorrow.
Offline Popwood
« Reply #3 on: February 10, 2011, 07:49:24 PM »
With revved rpms the advance advances. The light should be the same. My light has no adjustment. with rpms the centrifugal force overcomes the spring tension to allow the tming plate marks to rotate to the right, clockwise.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline jimkalfakis
« Reply #4 on: February 10, 2011, 07:58:36 PM »
so even if I rev it, it should always be on the F mark?
Offline yo2001
« Reply #5 on: February 10, 2011, 08:00:52 PM »
You got a fancy timing light ;D
You are basically presetting the timing advance on your timing light to 25 deg TDC, so at 2500rpm, you should see the "F" mark lined up. Set the timing light back to "0" and it should advance to the advance mark on the bike at 2500rpm.
73 CB350F
Offline jimkalfakis
« Reply #6 on: February 14, 2011, 06:34:45 AM »
Alright, my timing light is set to 0. At idle of approx. 1000 rpm, the F mark lines up. When I fast idle to 2500-2800 rpms, I have to advance the light to approx 52 degrees.
Without advancing the light, the timing pins when revved to 2500 or more. Are my springs too loose?
Offline Deltarider
  • I'm back
« Reply #7 on: February 14, 2011, 07:42:21 AM »
Your fancy strobe obviously measures degrees for a 4 cylinder. Our engines "count" as a 2 cylinder and since 52 divided by 2 is 26 - which is about the correct advance - you've done well.
« Last Edit: February 14, 2011, 07:46:57 AM by Deltarider »
CB500K2-ED Excel black
Offline jimkalfakis
« Reply #8 on: February 14, 2011, 01:28:46 PM »
Thanks DELTA! I just needed a little reassurance. The bike runs well but I know I still need a carb sync to finish the motor. I don't have much experience with this old bike.
