Author Topic: 022A Carb Float Bowl O-Ring Spec?  (Read 836 times)
Offline haroldhupmobile
« on: March 15, 2011, 11:37:11 AM »
Does anybody know it?  The usual places don't seem to sell just the o-ring and I can't find the spec to get one from a supplier.  Any help is appreciated.
“Remember, you can always find East by staring directly at the sun.”
-Bart Simpson
Offline phil71
Re: 022A Carb Float Bowl O-Ring Spec?
« Reply #1 on: March 15, 2011, 12:18:21 PM »
If you're referring to the fiber washer that goes between the seat and the carb body,
then I direct you to this>  http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=fiber+washer&langId=-1&storeId=10051&catalogId=10053
I used a unibit step drill to open it up just a little so the seat fit thru it, and that was a substantial savings over buying the fiber washers from some 'vintage vulture'.
if you're talking about the rubber gasket that seals the bowl to the carb, then I don't really understand your question.
« Reply #2 on: March 15, 2011, 01:34:32 PM »
Unfortunately, no.  The large o-ring that goes between the main bod of the carb and the float bowl.  It fits into a channel on the float bowl.
-Bart Simpson
Offline phil71
« Reply #3 on: March 15, 2011, 01:52:34 PM »
you're looking for replacements? Or hoping there's some generic fix?
http://www.siriusconinc.com/
« Reply #4 on: March 15, 2011, 01:59:49 PM »
Why not cut one yourself? In the slot you can put a bit of fuelresistent fluid gasket
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: March 17, 2011, 10:42:50 AM »
Did you try Feebay? I've seen just the bowl o-rings there before. Like $17 for four of them delivered.
http://cgi.ebay.com/ebaymotors/Honda-CB550-Float-Bowl-Gaskets-CB-500-CB-550-O-Rings-/180640063849?pt=Motorcycles_Parts_Accessories&hash=item2a0efca169
« Last Edit: March 17, 2011, 10:44:25 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
