Author Topic: K0 Alternator Cover Gasket Problem  (Read 4247 times)
Offline Bob Wessner
  • "Carbs Suck!"
Re: K0 Alternator Cover Gasket Problem
« Reply #25 on: April 25, 2006, 03:24:41 PM »
In following up with the theme of making your own Alternator Cover Gasket, Does anyone know what thickness of gasket material should be used for making the gasket. It seems to me that I read somewhere that the thickness of the alternator cover gasket is critical and that this was a reason for not using some type of gasket making goo.
Is the theory behind this that a thicker gasket would alter the relationship between the alternator parts? Seems like it would have to be very thick to do that. I was prepared to cut my own (until I realized my mistake positioning the new stock one). The material I was going to use seemed ever so slightly thicker, but also seemed like it might compress slight more.
Offline DiscoEd
  • Keeping it surreal!
    • My personal gallery is at:
« Reply #26 on: April 25, 2006, 03:35:29 PM »
Bob,
Yes, I beleive the relationship of the alternator parts was the issue that I'd heard of. I'm just not sure if there is any validity to it.
I've got a new gasket coming for mine, but I'm not sure that I can wait that long. So if I could find out what the correct material is, I might try to cut one.
Jonesy, is implying above that the goo works. I just don't know how comfy I feel with that.
Regards,
DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
2003 Suzuki Volusia Intruder
http://gallery.sohc4.net/main.php?g2_itemId=1954
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #27 on: April 28, 2006, 09:54:49 AM »
The thickness of the gasket might change the exact positioning of the
rotor with respect to the stator, but there are many tolerances that
affect that including the crankshaft positioning tolerances.  I think small
gaskets thickness variances would be FS 'n P.  ;D
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #28 on: April 28, 2006, 10:11:06 AM »
FS 'n P
Offline techy5025
« Reply #29 on: April 28, 2006, 07:09:56 PM »
Bob....   Fly S*** 'n the Pepper.    ;D ;D
2003 CBR600F4I
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #30 on: April 28, 2006, 07:11:53 PM »
Ah! <light bulb going on>
