Hey guys,
I have a CB400F that I have fitted a new OEM right hand switch gear from a CB350F. It's almost the same except that the 350 switch is grounded to the handle bar rather than connect to the neutral wire of the stock CB400F wire harness. At least that's the way I understood my mechanic.
Now the trouble is, with the Dyna ignition I have fitted, the amount of power going to the run/stop/run switch is too much for the switch to handle. It's draining the battery voltage drastically. When I take that switch out of the equation, the bike runs fantastically. When I connect it, it hardly starts and runs terribly.
I've been told I should put a relay on to take all that power load off the small switch. I installed a run/stop/run switch somewhere else in the wire harness.
I remember reading somewhere that when installing Dyna ignitions that it sometimes overpowers the tiny Honda switch. I can't seem to find anything about it. Has anyone got some advice for me? I'd rather use the original switch if I can.
Thanks,
Rick.
