Author Topic: 1974 CB750 stuck alternator rotor  (Read 2306 times)
Offline Monk
« on: April 10, 2011, 10:50:23 AM »
If I am trying to pull a stuck alternator rotor with a three-legged sprocket puller can I push against the reinserted center bolt (after removing the washer) or is this working against itself?
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
Re: 1974 CB750 stuck alternator rotor
« Reply #1 on: April 10, 2011, 11:41:13 AM »
Monk you need a tool. I have send along a picture to show you what it is. You just screw it in the rotor and it will pop right off. They are not that expensive either and saves time and trouble.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline Monk
« Reply #2 on: April 10, 2011, 02:00:18 PM »
Thanks for the reply.  I was trying to avoid buying the tool you mentioned.  The rotor did finally come off after two days of heart ache (I would have been better off getting the tool in the first place).  I hope I haven't cause any damage using my method.  Thanks again.
