Author Topic: Do CB650's (or 550's?) use O-rings around their cylinder sleeves?  (Read 2321 times)
Offline turkey2143
  • My parents think I'm crazy.
To my horror after fuddling to put my 1980 CB650 cylinder block onto my CB650 pistons with a friend for 45 minutes (oh noooo!!!) I checked bikebandit.com's parts fiche to double check my O-ring placements to find that I am missing part 5 in this diagram, which are the 4 O-rings that appear to go around the cylinder sleeves in between the block and my 1977 CB550 crankcase:
http://www.bikebandit.com/houseofmotorcycles/1980-honda-cb650/o/m1974#sch17510
I don't remember removing these from my CB650 parts bike's engine, but my memory is a little hazy on it.
On a second look, I checked the Honda Shop Manual that this forum has a link to:
EDIT- my picture link doesn't work anymore, so here is the site link for the 650 manual:
http://cosky0.tripod.com/sitebuildercontent/sitebuilderpictures/page07-08.jpg
It mentions some oil passageway o-rings, but not these 4. They aren't even listed on bikebandit's site for sale, but they came with my CB550 rebuild kit.
I'm doing paulage's CB550/650 big bore build, sans the 750 cylinder sleeves & pistons and instead using the 650 stuff, so can anyone confirm whether or not they go on a stock CB650? It'd also be nice to know if they come on a CB550, and as well as to folks' thoughts on whether or not they are necessary, as they do not hold piston pressure like the head gasket does.
Any input is appreciated
« Last Edit: April 11, 2011, 08:32:43 PM by turkey2143 »
Offline tomkimberly
Re: Do CB650's (or 550's?) use O-rings around their cylinder sleeves?
« Reply #1 on: April 11, 2011, 09:26:20 PM »
They are on mine. Do you need them?  I don't know.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: April 12, 2011, 12:34:47 AM »
They keep oil from seeping up between the sleeve and the block. Yes, the 550 and 650 both use them.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
