Author Topic: <<<the simple little question thread>>>  (Read 19238 times)
Offline vrenlos
Re: <<<the simple little question thread>>>
« Reply #75 on: May 16, 2011, 09:27:08 PM »
For what it's worth, I'd go with the aerosol if you can - I just did the same thing but with the liquid, and it's a big goopy, sticky mess.
1975 CB550K1
2009 Ducati Monster 696
Offline jorwesflow
  • we're not schizophrenic
« Reply #76 on: May 22, 2011, 10:02:43 AM »
just bought a duralast battery at autozone (fwiw), and it says to charge at 500ma for 12 hours. I only have as low as 1A to trickle charge. is that gonna be fine? I can't find a 500ma charger anywhere.
1977 CB550K
bollingball
« Reply #77 on: May 22, 2011, 10:37:31 AM »
The only charger I know of with that rating is one like you would use for a cell phone or something like that. look at one close you will see the ma rating stamped on it. can you post a pick of that battery how big is it?
Offline jorwesflow
« Reply #78 on: May 22, 2011, 10:43:57 AM »
1977 CB550K
« Reply #79 on: May 22, 2011, 11:02:19 AM »
Simple answer...no.
Don't bother reading the rest...
I mean it!  Stop right here.  Things will stop being simple, I warn you.
Hey, I'm not kidding, buddy!  Just move on to the next post.
....Ok, I warned you!
There are as many brands and styles of chargers as there are vehicle brands in the world. ... And, they all have different capabilities.
Some chargers list only their max capability.  Cheap chargers are seldom constant current type, or have a voltage regulator.  So, I have doubts your "1 amp charger" does so under all connected conditions.  But...
You didn't tell us the battery model numbers.
you didn't tell us the charger brand/model numbers.
You didn't tell us a BIKE brand or model number.
So, I suspect the information hiding was done so you could hear it was ok to do whatever you wanted.  So, go ahead!  It ain't my battery!   ;D
But, maybe you should 1/3 the charge time, or don't expect the new battery to achieve maximum potential.  It's all about the chemistry.  Ready for Chem 101?  It's really simple, you know.  ;D
Yes, you can damage a battery (catastrophically or subtly) by exceeding manufacturer recommendations.   (Kinda why they give you guidelines.)
Oh, and since you can't sop reading, here's another simple question.   ;D
The doctor says I should clean my fingernails with a tooth pick.  I only have a hatchet, will that be ok?  Will there be blood?  ;D
Oh, and here's another simple question.  How long will it take to get to Mars?  ;D
Is there a limit to the simple questions in a single post?
Cheers,   ;D
Offline jorwesflow
« Reply #80 on: May 22, 2011, 11:28:19 AM »
TT, seemingly infinite are the questions you have answered for me before! (probably a dozen or
so). never with such cynicism! I'll take what I can get. :)
pardon me... 1976 CB550F. charger is Schumacher MC-1. battery (above) is Duralast CB12A-A.
any advice, as always, is
not just appreciated, but is necessary to me being able to ride this first bike of mine down the street for the first time in my life. when i ask this question, there's a lot more at stake than a battery. I want to ride.
1977 CB550K
« Reply #81 on: May 22, 2011, 12:25:15 PM »
You just ignored all the smilies I put in the post?  :-\
I downloaded the operator manual for your charger.  Below is the bit you should read.
You have a manual charger.  Meaning: you can't just leave it unattended.  Assuming the battery is 50% discharged (a new one just activated is NOT 50% discharged)  It begins at a 1 amp rate and tapers down to .3 amps as it gets the battery toward full charge then CONTINUES at a .3A rate thereafter. which will over charge and begin damage to the battery at some point.  You will have to monitor the battery voltage and disconnect the battery when it reached 14.5V at the terminals.
I expect your charger is a constant voltage type.  It's a good brand, though.  They know their stuff, and put good info in their operation manual.  Useful charger, but needs intelligence on the part of the operator to employ properly, (which makes them different from automatic types).
I'd guestimate a newly activated battery would need 2-8 hours to reach the 14.5 V plateau.
Offline CycleRanger
  • No comment about being an
« Reply #82 on: May 22, 2011, 12:55:13 PM »
What 72-76 Honda street bike uses an ND tachometer with a 1000rpm=3000rpm gear ratio?
Tach looks identical to 750-550 etc. tach.
Simple enough. ;)
Offline db22
  • Old and in the way.
« Reply #83 on: May 23, 2011, 08:45:29 PM »
Over the weekend I broke a valve tappet cover -- there's a chip missing that leaves a hole about 4mm by 2mm.  Can I seal this with a dab of epoxy or even just cover it with some Gorilla Tape until the new cover arrives, or should I park the bike until the new part is delivered? Will be riding my daily commute, about 32 miles, no faster than 60mph. How much oil pressure is there behind those little covers at road speeds?
1975 CB550K (rider)
1975 CB550K (shaping up, slowly)
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride. . .
Offline db22
« Reply #84 on: May 23, 2011, 08:46:57 PM »
And another: Is there any difference between '75 550 F and K rear wheel hubs?
1975 CB550K (rider)
« Reply #85 on: May 23, 2011, 09:19:11 PM »
I would think a little bit of jb weld or something would be all right temporarily, especially if the o-ring is still doing it's job, all your gonna have is a oil leak anyway...messy but not serious if you replace the missing oil.  It's getting to be more simple little questions than answers in here, so I thought I'd take a stab at this one...here is another question...Has anyone ever noticed their bike to start a little easier with the kick over the starter when cold?  I was thinking maybe the starter motor is somehow using some of the spark energy.
Offline vrenlos
« Reply #86 on: May 23, 2011, 09:41:54 PM »
Does anyone know the size and threading of the small brass screws that hold the points on the the plate assembly?  One of mine was stripped to all hell by the PO.  Thanks.
1975 CB550K1
Offline db22
« Reply #87 on: May 24, 2011, 04:55:37 AM »
"Has anyone ever noticed their bike to start a little easier with the kick over the starter when cold?  I was thinking maybe the starter motor is somehow using some of the spark energy."
Seanbarney41: I have noticed that my CB550 starts cold on the first kick, even in very cold weather.  But, it doesn't take too long to fire up when I use the button, either.  IF everything else is in good order, my CB550 has been an easy starter, and I just like the feeling of kick-starting a motorcycle.  I hate that they have stopped putting kickers on bikes!  What are they thinking?  Oh yeah, they save five bucks in production costs.
1975 CB550K (rider)
Offline Radam
  • taco racer
« Reply #88 on: May 24, 2011, 06:28:37 AM »
My F3 seems to start better with the kick start. I rarely use the button because I like the kick better too.
vrenlos, I've used strips of beer cans, aluminum tape, and one of my friends recently used grip tape (sand paper with adhesive on one side) to keep handlebars from slipping. I've never tried to go from 1" to 7/8" though.
« Reply #89 on: May 24, 2011, 06:51:24 AM »
You can buy another used plate from any junkyard or used-part source, or a new one from Honda complete with points and condensors. No need to try to repair those backplates.
Offline vrenlos
« Reply #90 on: May 24, 2011, 06:57:00 AM »
It's actually just the head of the screw that's stripped, that plate is in pretty good shape.
1975 CB550K1
« Reply #91 on: May 24, 2011, 05:28:07 PM »
Ah. Then take one of the other ones out and go to Ace Hardware with it: they have them. :)
Offline thrutheframe
« Reply #92 on: May 28, 2011, 09:30:02 PM »
My simple question for tonight is:  will it hurt my clutch discs to soak in oil for 24 or more hours as opposed what the instructions on the box say? The instructions say to soak them for "several hours".  I walked out of my shop in a rush to get to my gig tonight and forgot them soaking in 10W40.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Grnrngr
« Reply #93 on: May 28, 2011, 11:24:57 PM »
Hmmm, lets see, yer gonna take them out of the oil, put them in the tranny case, then fill the case with oil...they'll prolly be OK....
you soak them in the oil, because if you installed them dry, since they are clamped together during installation, then added the oil to the case, there could be "dry spots" between the plates,and chances are good that they might not work as well, might cause uneven wear, and might wear out sooner...or worse...
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
« Reply #94 on: May 29, 2011, 05:30:13 AM »
Yeah I figured as much but there are no simple questions, just simple people.
Thanks for putting my mind at ease, now I can stop for coffee instead of going straight to the shop.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline longshanks
« Reply #95 on: May 29, 2011, 01:03:32 PM »
My bike is slowly blowing oil from the oil breather filter(is that what it is?) mounted on the back of the engine. It happens at freeway speeds as I noticed a streak of oil on my pipe. Is that normal?
cb450 K5
bollingball
« Reply #96 on: May 29, 2011, 01:15:47 PM »
long What bike and year?
What is not normal is for a filter to be there in the first place. Looks like someone has altered your breather system. It is normal for a little blow by gas to come out of there and when you put a filter there it will fill up and drip should be some kind of hose there where it goes to depends on year.
Offline longshanks
« Reply #97 on: May 29, 2011, 01:29:08 PM »
Sorry forgot to mention, its a 1976 Honda CB750K. And yes, it seems the oil is collecting on the aftermarket filter and then eventually dripping out because it becomes too saturated.
cb450 K5
bollingball
« Reply #98 on: May 29, 2011, 05:31:39 PM »
Long If you look at the service manual for a flow chart you will find how it was plumbed from the factory there are some post on this. The very early bikes ran a hose from the valve cover down to the ground by the back wheel. Later it was recirculated back to the engine.
Offline lone*X
« Reply #99 on: June 09, 2011, 12:42:09 PM »
My turn!  Anybody remember who was casting the 550 airbox boots (other than DSS) a while back?  There were some folks trying them and if I remember they were a little on the soft side.  Wondering how that all turned out since I need to buy a set of boots and would rather purchase them from a member if possible.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
