NO! Do not connect 12v across the gauge!!!
The circuit works by varying the current passing through the sender - 12V (14V at cruise) is never applied to the gauge. Applying 12V will probably burn it up if it isn't already.
If you want to test it use the ohmmeter (Rx1) - Place one lead on one terminal and just tap the other lead on the other terminal while watching the needle. If it wiggles then it's probably good. If the needle goes backward, reverse the leads.
An intermittent is usually a broken or loose wire.
Good Luck Tom
