Author Topic: Quick Mixture Question: If you're at WOT....  (Read 758 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: May 09, 2011, 01:00:43 PM »
... and you close the throttle a bit & the bike jumps, that's lean at WOT, right?
I'm second guessing myself.
Offline Jon
Re: Quick Mixture Question: If you're at WOT....
« Reply #1 on: May 10, 2011, 01:19:18 PM »
Probably, pull a little choke on while WOT, if it pulls harder your lean.
Cheers
jon
Honda CB550f
Honda VFR400
Ducati 900 S2
Moto Guzzi LeMans III
BMW R90S
« Reply #2 on: May 10, 2011, 01:33:55 PM »
if it hasnt approached high rpm and you close it suddenly and it feels like a splutter its going rich,if you close it slowly is it ok?
Offline grumpy
« Reply #3 on: May 10, 2011, 08:00:03 PM »
jon - good idea giving it some choke. I'll try it.
dave - this is at high revs and yeah, closing it slowly is OK.
« Reply #4 on: May 12, 2011, 12:31:47 AM »
its drawing fuel at these revs then your suddenly cutting off its air before its burned,your a tad rich in the main jet,the engines runs ok otherwise?
