Author Topic: 350f not running right ....please help  (Read 1485 times)
Offline mack82
« on: May 10, 2011, 05:19:54 PM »
somebody please help.  my bike is just dying after about ten minutes of riding.  i checked the stator and field coil and both rang out ok.  i know that its nothing with fuel delivery because everything was just cleaned etc...  could it be the rectifier?  or the voltage regulator?  u guys gotta help me please
Offline Triffecpa
Re: 350f not running right ....please help
« Reply #1 on: May 10, 2011, 05:27:23 PM »
put a volt meter on your battery with the bike not running.  You should see 12.5 volts or so.
Then start the bike up and run it up to about 3000 rpms  Hold it at that speed and put the volt meter back on the battery again.  You should see 14+ volts.  If you don't, then you have a problem with your charging system.  If you are getting 14+ volts, then you likely have a fuel problem.
Pull the gas line(s) off the petcock and with a nearly full tank of gas, put a new hose onto the petcock, open it up and drain the fuel out into a clean gas can or bucket.  You want to be able to watch the fuel flow out of the hose to check the consistent volume of gas coming out of the petcock.  Unless you can run a gallon or two out of the petcock with out any decrease in flow, you have some fuel flow problems.  Check the Reserve setting on the petcock also.
You might have a plugged up fuel cap vent that is not allowing much gas to flow out fast enough.
Tracy
Offline mack82
« Reply #2 on: May 10, 2011, 05:37:31 PM »
i appreciate the help.  thank u
Offline mack82
« Reply #3 on: May 10, 2011, 05:59:57 PM »
whats the best way to clean that vent?  i think youre right because when i opened the gas cap and turned the fuel on...the overflows started leaking which means that the bowls were not full when i was trying to run it
Offline Triffecpa
« Reply #4 on: May 10, 2011, 08:19:15 PM »
you can drill a hole in the underside of the gas cap with an 1/8" drill bit.  You only need to drill thru the sheetmetal plate in the middle of the cap, not thru the whole cap.
TR
Offline mack82
« Reply #5 on: May 11, 2011, 07:02:46 PM »
awesome, thanks for the help
Offline RickB
    • Pop Magazine
« Reply #6 on: May 12, 2011, 02:44:25 PM »
If it's not the fuel, you may have a charging problem. At least that's what my issue was. You can follow my trouble shooting here:
http://forums.sohc4.net/index.php?topic=87086
