Author Topic: CB750 F2 - wiring harness  (Read 955 times)
Offline dakota
« on: May 15, 2011, 03:51:17 AM »
Hi,
I am trying to put the wiring harness on the F2.  I am conneting ont he cables, but there is one green coming out the harness, its in the same bundle as the 4 cables for the coils. I don't know what the do with the green one. Any ideas?
Another question. On the magnetic switch there are 2 bolts: one (red) is going to the battery, the other is for the ground, but I can't find a cable for the connection. Is it connected do the cable coming from the frame or is that one going to the battery?
A lot of connection problems as you cn see?
please some help or some pictures of your installations!
regards,
gp
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
Re: CB750 F2 - wiring harness
« Reply #1 on: May 15, 2011, 04:41:20 AM »
The green wire goes to frame ground. This ground can be found on the front of the coil mount where it mounts to the frame. On the magnetic switch, the other side goes to the starter not to ground. The frame ground for the battery is connected to the rear engine mount on the battery box side of the bike.  Hope this helps.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline dakota
« Reply #2 on: May 15, 2011, 04:58:44 AM »
yes, thank  you.
