Author Topic: shifter shaft seal  (Read 16090 times)
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
shifter shaft seal
« on: May 19, 2011, 05:51:18 PM »
what is the technical name for the oil seal at the shifter(gear selector?) shaft, or an ebay link would be just as sweet. i need a new one and dont want to get the whole kit.
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline honda_jason
  • I have no idea what I'm doing
  • 1971 CB500
Re: shifter shaft seal
« Reply #1 on: May 19, 2011, 06:11:07 PM »
i just replaced mine...you can find it here: www.bikebandit.com part number 729774 (1989871-001)
Offline skamagedon
« Reply #2 on: May 19, 2011, 06:13:26 PM »
thumbs up! Also....nice bike
Offline honda_jason
  • 1971 CB500
« Reply #3 on: May 19, 2011, 06:20:29 PM »
thank you sir. make sure you put it in there good...goes in almost like a bearing. grease it up nice too!
Offline skamagedon
« Reply #4 on: May 19, 2011, 06:32:57 PM »
how difficult to get the old one out?
Offline honda_jason
  • 1971 CB500
« Reply #5 on: May 19, 2011, 06:37:43 PM »
pretty easy...just put a flat head inside it and wedge it out...when i put my new one in i greased it and pushed it in and then used a socket that was just smaller than it to push it all the way in
« Reply #6 on: May 19, 2011, 06:41:02 PM »
Simple with the right technique.  Pierce the old seal with a narrow, pointy, flat blade screwdriver about a blade width or two in from the outer rim.  Pries out easily after that.  New one just presses into place, but better to put a little tape on the shaft splines to keep from nicking the new seal lip.
Offline skamagedon
« Reply #7 on: May 19, 2011, 06:59:47 PM »
sounds like i dont need to remove the shaft or take the motor apart, am i correctly assumin?
Offline honda_jason
  • 1971 CB500
« Reply #8 on: May 19, 2011, 07:01:30 PM »
yupp you are correct. just drain the oil and take the left case off. if you cant get the old one out then youll have to take the clutch cover off and remove the clutch plates and basket and take the shaft out which makes it way easier without that much work.
Offline Johnie
« Reply #9 on: May 19, 2011, 07:08:23 PM »
Make sure you clean that shaft before sliding that seal in place too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #10 on: May 19, 2011, 09:14:34 PM »
You don't need to drain the oil, or take the shaft off.
Remove foot peg, shift lever, and sprocket cover, though.
Offline DanielB
« Reply #11 on: May 20, 2011, 08:34:14 AM »
Is there any other place to buy this seal?
It would cost me 7 dollars in shipping for the seal and its only a $4 part.
1977 CB550K - Project Thread: http://forums.sohc4.net/index.php?topic=80164.0
Other toys: 2003 Cobra | 2002 WS6
Offline Silverback
« Reply #12 on: May 20, 2011, 08:37:46 AM »
Do you have a local Honda dealer? They can order it for you.
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline Scott S
« Reply #13 on: May 20, 2011, 10:23:18 AM »
 Order two. There's a decent chance that you'll damage one.
 I used a piece of PVC pipe that was the same size as the seal. Pressed in in as even and flat as I could by and, then used the PVC pipe and a hammer to tap it in flush.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline jonlewis666
« Reply #14 on: October 14, 2012, 02:48:45 AM »
Thanks to all for the advice on the gearshift shaft seal issue so just thought I would drop in my post fitment advice? The sel on mine was 'toast' after I used the shaft as a handle when moving the engine lump around the workshop wilst doing a top-end overhaul (silly ejjit that I am!). Two things i learn the hard way, ruined three seals, for sure take out the shft from the clutch side, doesn't take long and use a genuine honda seal as regular ones donlt have the square cut edge.
Once shaft is out and recess cleaned up nice with planty of grease, new seal simply taps in with the aid of a righ size socket and plastic mallet and my previously 'incontinent' CB500K is now a joy to ride again.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #15 on: October 16, 2012, 09:05:41 AM »
While you're in there you might think about changing the output shaft seal and the oil-pump o-rings (3) as well. they all have a tendency to leak eventually.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline jonlewis666
« Reply #16 on: December 31, 2012, 03:14:35 AM »
Thanks Daunob, I did just that and apologies for not getting back sooner. Jon
Offline grasscutter
  • Love the CB650.
« Reply #17 on: December 31, 2012, 09:40:10 AM »
Huh??  From clutch side?
So, you're going to take the entire clutch basket out?
Why?
Let me just say this: NO!
Just do as the other posters said.
TwoTired summed it up nicely.  Here it is again, in case you posted your response without reading the rest of them.
<<<You don't need to drain the oil, or take the shaft off.
Remove foot peg, shift lever, and sprocket cover, though.>>>>
Pretty simple, eh?
Come on!  We're burning daylight!
Offline Mooshie
« Reply #18 on: December 31, 2012, 12:45:31 PM »
Why?
Pretty simple, eh?
Simple enough that even a girl did it! :-*
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline grasscutter
  • Love the CB650.
« Reply #19 on: December 31, 2012, 03:18:09 PM »
You're talking about the seal under the front sprocket?
Wouldn't recommend that unless you can provide personal documentation that you can do that seal without splitting the cases.
Doing a search under that subject, brings up many many 'opinions'!
I can say from personal experience, that the CB650 seal has a center ridge to it.
You will absolutely NOT get it installed correctly without splitting the case.
But yes.  Do the oil pump o-rings.  Easy to do while you're 'in there'.
Offline Pjm911
« Reply #20 on: May 26, 2014, 03:36:52 PM »
Just an update on this topic - I used partzilla.com and oem honda parts were $2.84 each, I bought 2 and shipping was about $5. I ordered 2 just in case.
Offline billingstitan
« Reply #21 on: May 26, 2014, 08:53:04 PM »
You can replace both the shifter seal and the seal under the sprocket by simply removing the side cover (and sprocket obv)
Best way I've found to extract them is to use a wood screw and CAREFULLY screw it into the rubber - don't go too deep and dont let it go sideways - pretty simple to accomplish. Once screw(a) are firmly set, just grip the screws w a couple pairs of pliers and pull evenly (you only need one screw for the shifter seal - two screws 180 degrees apart for the seal behind the sprocket)
It's explained above how to insert the shifter seal - the sprocket seal you need a very large socket - can pick up at harbor freight etc - PVC or whatev would prob do the same. Just needs to be same diameter as the outside of the seal.
Put a little fresh oil on the seal and the firmly tap it evenly into place. There is a lip but it snaps right in - just did mine two weeks ago.
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
Offline thwrightstuff
« Reply #22 on: July 29, 2015, 10:48:05 AM »
Sorry to bring this thread back from the dead, but I'm having the exact same issues with you '80 CB650C. I ordered one already and installed it, but it was a little too small and it said the was the OEM one for my bike. What should the dimensions be for this seal on my bike? Any links people post seem to be obsolete. Your help would be greatly appreciated!
I know more than you, except if you know more than me.
« Reply #23 on: July 29, 2015, 10:55:29 AM »
what is the honda part number of the one you ordered?
cross check it against this...
I think you are referring to #23 on the gearshift drum fiche.
http://www.cmsnl.com/honda-cb650c-1980-usa_model473/partslist/E++17.html#results
« Reply #24 on: July 29, 2015, 01:40:00 PM »
Hmm possibly, but I think the one I need is #24, form the looks of it. I just am not convinced it's the right size.
