Author Topic: Clubman bar problem  (Read 7010 times)
Offline longshanks
Re: Clubman bar problem
« Reply #25 on: May 28, 2011, 10:12:39 AM »
So just to be sure I'm adjusting the clamps below the fork nuts? And if so, both forks will slide evenly because they're mounted on the front tire spindle right?
Try unbolting the clubs and rotating them until the bolt circled in your picture is below the downward bend. The bar ends need to be angled more downward.
I already tried that. The fork nuts were STILL hitting the bars. I'm pretty sure the PO had lowered the front end, making the clubman bars installed wacky.
cb450 K5
Offline Bankerdanny
  • Endeavor to persevere
« Reply #26 on: May 28, 2011, 10:15:42 AM »
No doubt the PO installed shorter cables. You might be able to gain some distance with routing, but you may have to replace the cables in the end.
