Author Topic: Sluggish 500  (Read 1202 times)
Offline ben.cb500
Sluggish 500
« on: June 05, 2011, 08:13:31 PM »
my bike runs like crap.
1st year I had it I rebuilt the carbs with a keyster kit. ran crap.
this winter i had the head a cylinders sent out and reringed it...better, starts effortlessly, but still seems gutless.
I have done the tappets, points, condesors, plugs, timing but no carb sync. other than on the bench
today i went for a ride and it just seems like its being held back....removed the air filter, suspect it is cogged, although clean in color. it ran much better but still not great. often dies out at idle.
I get about 45 miles to the tank.....fwiw
so I dug out the old KEIHIN carb bits thinking maybe the Keyster stuff I put in is junk....The emulsions tubes are different, the original KEIHIN have a much different design. And the are 100's and if I am reading it right, 18's its stamped 18??  The needle are one rung up from the pointy end....
Any value in tearing down the carbs and replacing with the old stuff, save for new seals....or should I try something else.
I just get the sense that there is more power but i havent figured out how to tune it. i suspect a modern scooter would have no issue keeping up with my bike as it is.
any input?
« Last Edit: June 05, 2011, 08:23:06 PM by ben.cb500 »
Re: Sluggish 500
« Reply #1 on: June 06, 2011, 12:26:37 AM »
that 18 might be 98?one notch up from the lower end is rich,try it in the middle.
Re: Sluggish 500
« Reply #2 on: June 06, 2011, 01:03:02 AM »
I could be wrong but i am sure i read somewhere that keyster carb kits were crap, even if they are not, always try and use genuine Honda parts.....If you are only getting 45 miles to a tank something is very wrong......Also, try posting for another Toronto member to give you some help, there are some very clever guys on here in your part of the world..... ;)
« Last Edit: June 06, 2011, 01:05:39 AM by Retro Rocket »
Re: Sluggish 500
« Reply #3 on: June 06, 2011, 02:06:50 AM »
was the ignition timing done with a strobe?is the advancer not siezed up?check it with a strobe light and make sure it moves.
Offline ben.cb500
Re: Sluggish 500
« Reply #4 on: June 06, 2011, 08:15:54 AM »
will do with the strobe and check for advance.
The original Kiehin carb bits are stamped 100 Mains & 18 Slows both with the Kiehin logo on them. Have them soaking in SeaFoam to clean them up for reinstall. The original needles I pulled were set to second rung from pointy end, the KEYSTERS i put in were set at the middle.
Would it be reasonable to have 18's in it? The mileage was 47K miles when I got it. The pistons were in std spec and the cylinders just honed...
Will try with a strobe and see whats happening....any input appreciated.
« Last Edit: June 06, 2011, 08:17:30 AM by ben.cb500 »
Offline domer
Re: Sluggish 500
« Reply #5 on: June 06, 2011, 08:50:02 AM »
that is most definitely a 98 slow jet! I'd try for a plug chop (after checking what everyone else said) just to give you a better idea of whats going on in there...
Re: Sluggish 500
« Reply #6 on: June 06, 2011, 12:36:03 PM »
the slow jet wont be 98,,more like 38/40/42?the discharge end of the slow jet is lucky to be one mill wide let alone have a .98 hole drilled through it.,look here.
http://forums.sohc4.net/index.php?action=dlattach;topic=5410.0;attach=3002
Offline domer
Re: Sluggish 500
« Reply #7 on: June 06, 2011, 01:17:45 PM »
 ::) im an idiot.... reading and typing at the same time.... meant to say that is not a 18 on the slow jet. sorry.
Offline ben.cb500
Re: Sluggish 500
« Reply #8 on: June 06, 2011, 03:49:27 PM »
the original kiehin slow jet is marked 18....checked them all...closely......should I be hunting down 40's before I rip into the carbs?
« Last Edit: June 06, 2011, 04:02:20 PM by ben.cb500 »
Re: Sluggish 500
« Reply #9 on: June 06, 2011, 04:36:56 PM »
I don't see how it could run with #18s as pilots.  #40 was stock.  You sure the ones you have weren't drilled?
An 18 would have a .18mm hole within, instead of the usual .4mm
Are all the head pipes getting even heat?
What are your spark plug deposits telling you?
Stock paper air filters are really only useful for about a year on American models.  Then replacement is required.  For economy, I switched to the UNI NU 4055.
I don't trust the Keyster kits.  Unless the Honda parts are corroded/damaged, I much prefer them.
Offline phil71
Re: Sluggish 500
« Reply #10 on: June 06, 2011, 04:40:24 PM »
bad mileage and no power point to wrong mains and/or needles set too high.
Offline ben.cb500
Re: Sluggish 500
« Reply #11 on: June 06, 2011, 09:00:35 PM »
My apologies to everyone trying to help me out...they are 40s...i was looking at the jet that fills the bowl...?? Im very tired...
Just finished putting the old keihin stuff back in. Started at puck drop fired at end of bostons thumping of vancvr...she runs way worse. Wont idle, no power suspect no fire in one or some cylinders.
Could i have put the 100 in upside down? The 100 markings stick out, narrow passage sits inside near needle.
Running outa steam....shldnt be this tough
Re: Sluggish 500
« Reply #12 on: June 07, 2011, 12:09:46 AM »
the jet id should be visible,have the carbs been blown through with compressed air?have the emulsion tubes been removed and cleaned?is someone close by who can maybe have a look?when you put the cam back in it was timed correctly,not one tooth either way or something?
