Author Topic: Popping and smoke  (Read 1437 times)
1979CB650_Chris
Popping and smoke
« on: April 23, 2006, 11:53:54 PM »
Hey all,
Ok so I heard some popping or backfiring through the carbs so I riched the mix a bit and it stopped!
So later Im out cruising and then I notice the popping returned this time with blue/whiteish smoke pouring out the back.  Any ideas ehat this could be.  It only smokes when it pops, and it pops off and on, very weird.
Thanks
Chris
eldar
Re: Popping and smoke
« Reply #1 on: April 24, 2006, 08:29:13 AM »
good change you are running TOO rich. check your plugs to be sure. You could also be getting oil blowing by the rings. I know if that happens, the smoke can be white in some cases. I had an old nissan that had this happen. oil was overfilled and it blew white smoke till the excess was used up.
