Author Topic: Whats that Knock!  (Read 905 times)
Offline MILO
Whats that Knock!
« on: June 15, 2011, 04:11:06 AM »
Howdy,
I've got a kawasaki GT550 thats done god knows how many miles.
It runs good, blows no smoke. but does have a small oil leak. can hear a bit of valve chatter.
When it is at idle, or say around 1000-1500rpm, there is a knocking sound coming from the bottom end, but as soon as the revs pick up to above 2000rpm the sound goes away.
What do you reckon it could be?
« Last Edit: June 16, 2011, 05:10:04 AM by MILO »
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Knock Knock!
« Reply #1 on: June 15, 2011, 07:36:42 AM »
Does the sound change when you pull in the clutch?
Have the carburetors been synchronized/ worked on lately?
« Last Edit: June 15, 2011, 07:38:43 AM by Industrial-sized Dukiedook »
Offline MILO
Re: Knock Knock!
« Reply #2 on: June 16, 2011, 04:37:04 AM »
sound doesn't change at all when the clutch is pulled in.
Sound's definitely coming from the front of the engine, not the gearbox.
I just bought it, its been used as a daily driver by the PO for the last year, i doubt its had the carbs balanced or worked on in the time he had owned it.
Offline MILO
Re: Whats that Knock!
« Reply #3 on: June 18, 2011, 05:42:23 PM »
anyone?
« Reply #4 on: June 18, 2011, 11:35:28 PM »
Time for a full tuneup, then come with Q's.
Offline 333
  • Time for change
« Reply #5 on: June 19, 2011, 08:19:13 AM »
That must be one of those models not imported into the U.S..  There was a Kaw GPZ550, and Suz made a GT500(2 stroke).  But, no matter.
If a tune up doesn't do the trick, you'll probably need to do a rebuild. Crank and rod bearings.  There is no easy fix if that is what's wrong.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
