Author Topic: petcock compatability?  (Read 2015 times)
Greg
« on: May 03, 2005, 11:15:54 AM »
hey all...
anyone know if a cb650 petcock is compatible with a 1980 cb750 custom tank on a 76 cb750f bike?
phew, what a cannibal!
thanks!!
Offline cb650
Re: petcock compatability?
« Reply #1 on: May 03, 2005, 03:00:38 PM »
It might be the same as a 81/82 650.  are the 750 carbs CV's?
                           Terry
Greg
« Reply #2 on: May 03, 2005, 03:14:44 PM »
terry -- thanks for the response.
the carbs are sei kin (sp?), just finished rebuilding them (thanks everyone!!)
what are "CV" carbs?
thanks!
greg
Offline cb650
« Reply #3 on: May 03, 2005, 03:28:08 PM »
Constant Velocity.  Depend on air opening the jets up intsead of a slide connected to the cable.  Are the tops round?
                  Terry
Greg
« Reply #4 on: May 03, 2005, 03:30:32 PM »
yes, they are round -- screw on tops, not the oblong type that i have seen on some other 750 carbs
greg
Offline cb650
« Reply #5 on: May 03, 2005, 03:39:24 PM »
Should be the same as the 81/82 650.  Never compared them side by side with the 750 but might be. Someone told me the carbs where the same as the 750 and they look it but he was sellin them. Older 650s had smaller petcocks.
I have one some where if you have a calliper we could compare mesurments.
              Terry
Greg
« Reply #6 on: May 03, 2005, 03:43:31 PM »
terry
sure, dig it up.  i've got a caliper...
greg
Offline cb650
« Reply #7 on: May 03, 2005, 03:54:16 PM »
Will have somethin tomorrow.  IM might work good for that.    cb650sohc4@hotmail.com  around 3 pm moutain.
                           Terry
Greg
« Reply #8 on: May 04, 2005, 04:19:52 PM »
terry
oops, soory.  i am just now getting in front of the computer again.  ill pull out the caliper and petcock tonight and see what i come up with and email you
greg
Offline cb650
« Reply #9 on: May 05, 2005, 06:54:49 AM »
I only have a set of dial callipers that are in inches.  The od of the tank bung is .700 (38 or so mm?)
with a 1.o metric thread.  The output for the fuel line is .310
                     Terry
