Author Topic: Longer alternative swingarm for a 750K2?  (Read 858 times)
Offline niels.d
« on: June 18, 2011, 04:10:24 PM »
A while back I think I read that the later cb750s have longer swingarms by a couple of inches and they bolt right up to the older frames, is this true? Also, are the shock mounts further back? Would the geometry change much with the stock shocks? I assume they'd be a little lower.
Is there any other swingarm worth looking into?
Thanks,
Niels.D
Re: Longer alternative swingarm for a 750K2?
« Reply #1 on: June 18, 2011, 06:47:24 PM »
I measured the swingarm on a K7 parts bike. The distance from the center of the pivot bolt to the rear of the arm, where the adjuster butts up, is 20". The distance from the pivot center to the center of the lower shock bolt is 16 3/4", measured on the right side of the frame.
bollingball
« Reply #2 on: June 18, 2011, 06:57:21 PM »
niels.d What is it you are trying to do? I think HondaMan would be the one to PM
Offline niels.d
« Reply #3 on: June 19, 2011, 01:33:59 PM »
Thanks, I'll measure my K2 when I get home and see how it compares.
My new seat doesn't have as much clearence for the rear 18" wheel so I thought if the swingarm was a bit longer there would be more clearence.
