when i first got my bike, the ritual was to pull the choke all the way out, then give the throttle a few twists, turn the idle screw way up, then hit start and give half a twist to the throttle.
have you checked the choke linkage at the bottom of the carbs? i've re-installed the cable incorrectly before, and the choke feels right, but isn't actually functioning right. sometimes it's not the cable itself, but the way the (platic) choke cam is positioned is incorrect. this was buggered on mine once, and i ended up with the exact issue you're having.
