Hello to all-
Still having problems with the 400f..so we,re all on the same page, I'm calling the cy#'s from left to right,as seated on the bike, #1,2,3,4. previously, the bike was running on all four, then it went to #1 and #2. pipes 3,4 were cold. Today, I tried again,and I have #2 and 3 pipes hot and #1 and 4 cold!! The bike starts right uo, has Iridium plugs and the carbs have been rebuilt,after soaking for a week in Yam carb cleaner. Then the carbs were removed again and that's where I'm at now.I checked for spark on #1 and # 4(today's cold ones) and I did have spark..Any ideas ? Thanks in advance..hate to remove the carbs if there is an ignition problem as well. Also need to address a tinny sound in the front,lower case..I suspect at 14K ,it's the camchain? We tried to loosten the adj. nut,but it wouldn't budge and didn't want to shear it.Am I putting the engine in harm's way?..also read ,that will happen if carbs aren't right? Such a sweet bike, I want to ride it!! I thought it gave me the LOOK when I passed the garage on the 76 Bonnie!
All the best,
John Coryea
1977 cb400f
